QM: 1D Potential Well Spring - Energy Levels
5 replies · 2K views
RJLiberator
1D Potential V(x) = mw^2x^2/2, part of a harmonic oscillator.
Suppose that the spring can only be stretched, so that the potential becomes V=infinity for x<0. What are the energy levels of this system?
I argued my way though this problem by the following:
We know that V(x) = infinity
V(0) = 0
V(x) = 0 otherwise
From our typical energy levels we know E_n = ħw(n+1/2) for n=0,1,2,3,...
But there is a barrier at x =0. Therefore we need x=0 to have E=0.
Energy levels are thus:
E_n = ħw(n+1/2) with n=1,3,5,7,...
One can see this though the wave function graphs: https://i.stack.imgur.com/rb340.gif
Is that argued properly? Did I find the right solution?
BvU said:
What are the boundary conditions at ##x=0## ?
I thought it was V(0) = 0. Did I interpret this incorrectly? Since the spring can only be stretched and not compressed?
I mean the conditions imposed on the solution . You want to make a distinction between the independent variable ##x## and the solution ##\ \psi(x) \ ## that has to satisfy a second order equation (##\ {\mathcal H}\psi = E\psi\ ## in your case) plus two boundary conditions.
I don't want to confuse you, though: your line of thinking is correct; it's just the wording that is unfortunate:
The solution for x < 0 is ##\ \Psi(x) = 0\ ## and at ##\ x=0 \ ## the boundary condition is that the ##\ \Psi \ ## has to be continuous.
The first derivative does not have to be continuous at ##\ x=0 \ ## because the potential function isn't continuous either (I silently hope a theoretician will improve on this somewhat).
At the turning point (Where ##\ V(x) = E\ ##) the situation is different and both ##\ \Psi \ ## and its first derivative have to be continuous.
@BvU sorry for not getting back to you earlier in this thread -- but your help was spot on. It was a much more basic question then I assumed and I got full credit for it, partially thanks to your guidance.
Cheers.
