Quantum Concepts Homework: TRUE/FALSE Statements
  • Thread starter Thread starter s_stylie0728
    Concepts Quantum
The discussion revolves around the true or false evaluation of several quantum mechanics statements. Participants express uncertainty about the nature of wave functions, with the consensus leaning towards the idea that all objects, not just small ones, have wave functions. The second statement regarding electrons showing wave-like interference is debated, with some affirming its truth based on experimental evidence. Clarification is sought on the relationship between the wave function and probability density, with agreement that the absolute value squared of the wave function represents probability density. Overall, the conversation highlights the complexities of interpreting quantum concepts and the need for precise understanding.
s_stylie0728
TRUE or FALSE for each statement:
*Only very small objects have a wave function.
*Electrons show interference effects like waves.
*The wave function times the volume gives a measure of the probability of finding a particle in a particular region.
*The absolute value of the square of the wave function can be thought of as a probability density.
*No two electrons may occupy the same quantum state in an atom.
*Two photons may occupy the same quantum state.
I'm finding vague answers to these concepts in my book, but I just wanted some clarification because it's hard to completely digest the language used. I've only heard of wave functions in quantum, so I'm assuming the first is true? The second is false, because the idea of an electron in quantum is probability, not a physical particle itself. The third statement is logical to me, but anytime I've normalized a probability integral I've always used the absolute value of the wave function squared. So I'm not sure about that. In that regard, the fourth statement I'm familiar with, but I'm not sure if it's defined as the "density". The fifth statement is true. And I'm almost positive the sixth is true because photons are bosons.
Any corrections of my logic or guidance? I would appreciate it!
The first seems true, but yet, everything has a wave function, and everything "obeys" if you will quantum physics. A human would defract through a doorway, were he to take 1 step every several billion years or so. Beware of this question, it is false, yet only seems true.
The second seems true to me. Electrons will behave like waves in double slit experiments, showing an interference pattern, but when you try to 'detect' them, you cause them to recoil and pickup their particle properties.
Third is false, it's the wave function squared.
fourth is true.
fifth is true
Not sure about the 6th, if you say true, so be it
It was right! Thank you very much :)
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
