Quantum Mechanics Infinite Well Help
NIQ
Hello all,
I just ran across this forum thanks to google and decided to register and ask for some help on my homework!
I'm in 2nd year university and we have a problem set due on Friday and this is the question on it:
A particle of mass m moves in one dimension in the infinite square well defined by:
V(x) = 0, if -a < x < a
V(x) = ∞, if |x| > a
Suppose that at time t=0 the wave function is
Ψ(x, t = 0) = A(a^2 - x^2)
where A is a normalisation constant.
a) Find the probability P_n of obtaining the value E_n of the particle energy, where E_n is one of the energy eigenvalues.
b) Determine the expectation value <E> of the energy.
I started to do part a) but it seems very wrong. What I did was try to normalize the function to unity so that
A^2*∫(from -a to a) (a^2 - x^2)^2dx = 1
and solving for A i found
A = sqrt((15*a^5)/(8*a^10 - 15*a^8 - 10*a^4 + 3))
This value seemed way too complicated but I kept going anyways hoping it would simplify, what I did next was try to calculate A_n such that
A_n = ∫(from 0 to a) dx*Ψ(x,0)*Ψ_n(star)(x,0) = ∫(from 0 to a) dx*Ψ*sin((n*pi*x)/a)
but then once again I got some fairly complicated function so I stopped.
Can anyone help me out here? I am very lost!
Thanks!
I'm a bit confused as to how you got your value for A.
So you have:
A^2 \int^a_{-a} (a^2-x^2)^2 dx=1
A^2 \int^a_{-a} (a^4+x^4-2a^2 x^2) dx=1
A^2 [a^4 x + \frac{x^5}{5}-\frac{2a^2x^3}{3}]_{-a}^a =1
A^2 [2a^5 + \frac{2a^5}{5}-\frac{4a^5}{3}]=1
A^2 [\frac{16a^5}{15}]=1
A^2=\frac{15}{16a^5}
A=\sqrt{\frac{15}{16a^5}}
I'm not particularly sure what you're doing for the second part. My guess (and I'm actually learning this stuff right now too) is that you should find A(k) (the amplitude function, i.e. the transform from x to k) and then relate the probability of finding E_n with finding the corresponding k_n where
k_n = \sqrt{\frac{2m}{\hbar ^2}E_n}
and
E_n = \frac{n^2 \pi^2 \hbar^2}{2 m L^2}
Of course, I could be completely wrong. I would extend that definition onto the third part by finding the expectation value of k.
Maybe someone else can be more helpful.
Ok the first part helped, I see what I did wrong, as for the rest of it I did something similar to what my professor showed us.
We learned that: P_n = |A_n|^2
And to find A_n you have to do the following:
A_n = \int^a_{-a} \psi(x) \psi^*_n dx
where \psi^*_n = A (a^2 - x^2) sin(\frac{n \pi x}{a}) dx
after some rough integration and simplifying I got:
A_n = \frac{60 n \pi + 120 cos(n \pi) + 15 n^2 \pi^2}{8 n^3 \pi^3}
And so if you square this you get P_n
To find &lt;E&gt; this is what I did:
&lt;E&gt; = \frac{&lt;p^2&gt;}{2 m}
&lt;E&gt; = \frac{-\hbar}{2 m} \int^\infty_{-\infty} \psi^* (x) \frac{d^2}{dx} \psi (x) dx
\cdots
&lt;E&gt; = \frac{-\hbar}{2 m} \sqrt{\frac{15}{16 a^2}} (-x^2) \vert^\infty_{-\infty}
Which doesn't seem like a good final answer... because it gives me 0 right?
Gonna try to figure out what I did wrong.
Thanks for the help though!
<E> depends on the Energy of each of the "single" square-well wave functions,
that is, on "n" - it's an average of how much of each wave you actually have.
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
