Quartz Clocks (Battery Operated)
  • Topic: Electrical
  • Thread starter John1397
    Clocks Quartz
9 replies · 6K views · last reply
John1397
I never had quartz clock I see you need to use carbon battery, I am thinking start with 1000 ohm resistor and see if clock runs with alkaline battery if not just keep lowering resistance.
I run all my clocks with alkaline batteries. Where did you read that carbon batteries are required?
I'm with @anorlunda -- I don't understand your question. Do you have a datasheet for the clock you are asking about?
Or perhaps are you asking about how to build a crystal oscillator circuit? There are some requirements on the oscillator circuit (like using an unbuffered inverter for some configurations), but you would need to tell us more in order for us to help you.
Circuit schematic of a 20 MHz crystal oscillator using two 40106 inverters U1:A and U1:B, with R2 1M feedback resistor, R1 270 resistor, crystal X1, and two 10pF load capacitors C1 and C2 to ground, output labelled Square wave.
https://www.gadgetronicx.com/square-wave-generator-crystal-oscillator/
A crystal regulated wall clock will run on any battery voltage from about 1.1 volts to 2.0 volts. I use rechargeable Ni-Mh cells at about 1.2 volt.
Do NOT use a resistor. The crystal oscillator runs continuously, but once each second the clock takes a short pulse of charge from the battery to advance the clock mechanism. A resistor will drop too much voltage during the pulse, which will then upset the oscillator.
The manufacturer in China says not to use rechargeable or alkaline batteries even Seikos website says no alkaline batteries, seems to me on DC you only have volts and amps.
See what a seller on Ebay writes about batteries.
  • Screenshot of an eBay listing description for a clock movement, with red text on steps to install the hour, minute and second hands and a warning to use carbon batteries, not high-energy alkaline ones.
All battery-operated equipment must run off a range of voltages, since batteries vary over their useful life. Both Zn-C and alkaline batteries are nominally 1.5 V and spend most of their life between about 1.5 - 1.3 V
NiCd and NiMH have a lower voltage, starting around 1.3 V and spending most of their life around 1.2 - 1.1 V, so I can see why they might not work. And I certainly have equipment which does not work with rechargeables (on a one to one replacement basis) or works only briefly with a freshly charged battery.
Alkaline batteries are preferred for higher current loads and because they may(!) be less likely to leak if left in past their useful life.
Zn-C I've seen specifically recommended for low-drain applications like clocks.
Clocks are also less likely to leak as they are not usually on stand-by: they operate all the time and you notice quickly if the battery reaches the end of its useful life.
If the current demand of the short pulses is significant, I'd have thought designers would include a bit of capacitance to support the transient load.
Quote from above image: "Too strong electricity will damage the movement."
OMG....
  • Wow
  • Haha
Somebody thinks this will work three diodes in row cuts voltage from 5 to 1.5.
  • Schematic titled Quartz Clock Power Supply: 5V through R1 1K, two parallel C1 and C2 22 uF capacitors to GND, and three 1N4936 diodes D1, D2, D3 in series to 1.5V.
"Somebody" is not a valid reference at PF. I checked the datasheet for those diodes and this schematic is obviously in error. Lordy.
Thread is closed temporarily for Moderation...
