Question about Average Velocities, vectors, kinematics
The discussion revolves around a hill walker's average velocities while traveling west and then east. The walker initially covers 6.38 km at 2.81 m/s west, then turns around and walks east at 0.327 m/s. A calculation attempts to determine the distance walked east, but it lacks clarity due to missing units in the equations. A participant points out the importance of including units for accurate communication of the calculations. Clear representation of units is essential for understanding vector addition and kinematics in this context.
eatingblaa
1. In getting to his destination, a hill walker walks with an average velocity of 1.22 m/s due west. This is because he walks 6.38 km with an average velocity of 2.81 m/s due west, turns around 180 degrees and walks with an average velocity of 0.327 m/s due east. How far east did she walk (in km)
2. Vector addition/ subtraction
2.81 - 0.327 = 2.483
2.81 = 6,380
1 = 2270.46
2.483 = 5637.56
6380 - 5637.56 = 742.44
Can someone please confirm if this is right ?
Welcome to PF.
It's unclear what you are trying to write, because you have left out units. Saying 2.81=6,380 is just plain false, it's like saying 1=2.
For example:
1 inch = 2.54 cm is a correct statement
1 = 2.54 is a false statement
If you were to include units in your equations, it might be clearer just what you're trying to say.
