How Does a Dielectric Material Affect Capacitor Capacitance?
  • Thread starter Thread starter predentalgirl1
    Dielectrics
predentalgirl1
A capacitor has a capacitance of 50 pF, which increases to 150 pF when a dielectric material is between its plates. What is the dielectric constant of the material?
C = 150 pF and Co = 50 pF
Therefore Dielectric constant K = C/Co
= 150 pF/ 50 pF
= 3
Correct.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
