What Is the Acceleration of a Charged Sphere Fired Toward a Fixed Charge?
The discussion revolves around calculating the acceleration of a charged sphere moving towards a fixed charge. The initial attempt used the formula for acceleration based on Coulomb's law but encountered errors in integrating acceleration to find velocity. Participants suggested using the conservation of energy principle as a more appropriate method for determining the sphere's position when its speed is 20.0 m/s. This approach involves equating initial and final potential and kinetic energies to solve for the required variables. Ultimately, the conservation of energy method was confirmed as the correct approach to resolve the problem.
miniake
[SOLVED] Question about Electric field.
A point charge q_{1}=15.00\mu C is held fixed in space. From a horizontal distance of 3.00cm , a small sphere with mass 4.00*10^{-3}kg and charge q_{2}=+2.00\muC is fired toward the fixed charge with an initial speed of 38.0m/s . Gravity can be neglected.
What is the acceleration of the sphere at the instant when its speed is 20.0m/s ?
Express your answer with the appropriate units.
a = \frac{k*q_{1}*q_{2}}{m*r^{2}}
a = \frac{9*10^{9}*15*10^{-6}*2*10^{-6}}{4*10^{-3}*r^{2}}
a = 67.5 * \frac{1}{r^{2}}
By integration,
v = -67.5 * \frac{1}{r} + C
Initial conditions: v = 38 m/s, r = 0.03m
38 = -67.5 * \frac{1}{0.03} + C
C = 2288
v = -67.5 * \frac{1}{r} + 2288
When v = 20m/s,
20 = -67.5 * \frac{1}{r} + 2288
r = 0.029761904
a = 67.5 * \frac{1}{0.029761904^{2}}
a ≈ 76200 m/s^{2}
Since both charges are +ve,
a = -76200 m/s^{2}
However, the solution is not correct.
May anyone pointing out the errors? Thank you very much.
By integration,
C = 2288
When v = 20m/s,
r = 0.029761904
a ≈ 76200 m/s^{2}
a = -76200 m/s^{2}
Hi miniake, Welcome to Physics Forums.
I think the problem lies with your assumption that you can integrate the acceleration with respect to distance to yield velocity. Velocity is the integral of acceleration with respect to time.
Have you considered using a conservation of energy approach to find the separation for v = 20.0 m/s ?
Hello miniake
What is the correct answer ?
Edit :Conservation of energy is the correct way to approach the problem.
Thank you gneill.
It works, using the formula U_{1}+KE_{1} = U_{2}+KE_{2}.
Thanks again.
Tanya Sharma said:
Hello miniake
Using the above approach will work.
