Learn How to Solve a Difficult Homework Question on Hooke's Law
  • Thread starter Thread starter charikaar
    Hooke's law Law
The discussion revolves around solving a homework problem related to Hooke's Law, involving a 180g trolley attached to a spring with a spring constant of 50 N/m. Participants calculate the initial acceleration of the trolley using F=ma and find the initial energy stored in the spring using the formula W=1/2kx^2. There is some confusion regarding the correct application of formulas and unit conversions, particularly in determining the force and energy calculations. The final speed of the trolley is linked to the transformation of potential energy into kinetic energy, with participants seeking clarification on the equations needed for the solution. Overall, the thread highlights the challenges faced by students in understanding the principles of physics and applying them correctly.
charikaar
Hello,
I found one of my this homework question difficult and was wondering if anyone could please help me.
A 180g trolley is placed on frictionless air track. One end of the trolley is attached to a spring of spring constant 50 N/m. The trolley is pushed against a fixed support so that the compression of the spring is 8 cm. The trolley is then released.
(a) What is the initial acceleration of the trolley when it is released?
(b) What is the initial energy stored in the spring?
(c) Calculate the final speed of the trolley along the frictionless track. You may assume that there is 100% transfer of energy from the spring to the trolley.
Any help would greatly be appreciated.
charikaar
(a) F = ma
(b) W = \frac{1}{2}kx^2 You can obtain that by integrating, but I'm not sure if you're familiar with that stuff.
(c) Energy principle
hello,
Thanks for the quick reply.
Mass of trolley: 180g or 0.18 kg
compression: 8cm or 0.08m
Using F=extentionxconstant to find Force
50/0.08=625N
Now using F=ma to find acceleration
625/0.18=3472.22...Am i correct?
(b) using W=1/2kx^2
25x0.64=16J
(c) I've no idea how to start this one.
thank you.
Charikaar
(a) Instead of calculating the force right in the beginning, solve the problem with the letters, and into the final equation, plug in the requested stuff. Oh, and F = -kx, not -k/x
(b) Are you using SI-units? I got a different answer.
(c) What sort of energy does the potential energy of the spring transform into?
Hi again,
I've just started AS physics and am not familiar with this stuff much. I don't know where does my teacher get these question from when they are not in the book.
(a) k=50 N/m, x=0.08 m using F=kx, F=50x0.08=4N
Now using F=ma to acceleration
a=F/m, 4/0.18=22.22...N/mkg
(b) This is AS Physics question.
Elastic Potential Energy=1/2xstretching forcexextension
=1/2x8x0.08=0.32J
(c)I think it transfers to energy of movement. Could you please give me equation for the solution.
Thanks for your help.
Charikaar
(a) Correct. From F = ma, we can see that the unit of F is kgm/s^2 This divided by kg, we get m/s^2, which is the unit of acceleration.
(b) My answer's half that.
(c) Kinetic energy: \frac{1}{2}mv^2.
