Solving Pulley Questions: Mass, Friction, and Tension Calculations
In summary, a block of mass 2kg and 6kg are connected by a massless string over a pulley in the shape of a solid disk having radius R=0.25m and mass 10kg. These blocks are allowed to move on a fixed wedge of angle 30\circ the coefficient of kinetic friction block is 0.36. The tension in the string will be different on either side of the pulley due to its mass, and the acceleration of the blocks can be determined by setting up and solving force equations. The acceleration will remain constant until one of the blocks comes into contact with something.
semc
368
A block of mass 2kg and 6kg are connected by a massless string over a pulley in the shape of a solid disk having radius R=0.25m and mass 10kg.These blocks are allowed to move on a fixed wedge of angle 30[tex]\circ[/tex] the coefficient of kinetic friction block is 0.36. Find the acceleration of the blocks.
Hmm how do you solve questions that involve pulley? The second part of the question ask to find the tension in the string and the tension is different. Why is that so? Shouldn't the tension be same since the string is connected?
In addition to your force equations for each mass, you'll need a torque equation for the pulley.
The tension would be the same throughout the string if the pulley were massless, but since the pulley has mass the tension on either side of the pulley will be different. (If the tension was the same, there would be no net torque to accelerate the pulley.)
So if the blocks keep sliding to a point whereby the acceleration is zero then the tension will be the same? Thanks doc :smile:
I'm not quite sure what you mean. As the blocks slide, the acceleration remains constant. (Until one of the blocks slams into something, of course.)
I mean will there be a point where the net force acting on the blocks are zero so the tension will be the same?
No. The net force and the resulting acceleration is determined by the masses and the angle of the incline. By setting up and solving your force equations (from Newton's 2nd law) you'll be able to determine the acceleration. For a given set of conditions, the acceleration is constant.
1. What is rotational motion?
Rotational motion is the movement of an object around an axis or center point. It is also known as circular motion.
2. What factors affect rotational motion?
The factors that affect rotational motion include the mass of the object, the distance from the axis of rotation, and the applied force or torque.
3. How is rotational motion different from linear motion?
Rotational motion involves circular movement around an axis, while linear motion involves movement in a straight line.
4. What is angular velocity in rotational motion?
Angular velocity is the rate at which an object rotates around an axis. It is measured in radians per second (rad/s) or degrees per second (deg/s).
5. What are some real-life examples of rotational motion?
Some common examples of rotational motion include the rotation of a tire on a car, the spinning of a top, and the motion of a ceiling fan.
