Question on spherical integration
PsychonautQQ
So if you integrate over a spherical area, say a ball of radius 1, then 0≤p≤1, 0≤θ≤2∏, and 0≤∅≤∏. My question is why don't you integrate ∅ between 0 and 2∏? I mean if you are integrating over a sphere then you have to go around it vertically AND horizontally completely? wouldn't both the angles be from 0 to 2∏?
Thanks genius's :D
edit: does it have something to do with the fact that you add a p^2sin(phi) when integrating in spherical coordinates?
Thanks genius's :D
No, it's much simpler than that.
A point (r, θ) describes any point in the horizontal plane, and as you know, 0 ≤ θ ≤ ##2\pi##. To describe a point in space, and we can do this by adding a 3rd coordinate, ##\phi##. All we need to identify this point in space is a direction angle, ##\phi##. Keep in mind that ##\phi## is measured from the positive z-axis, so having a range of [0, ##\pi##] gets us all the way from straight up to straight down.
Note that r is the distance from the origin to the point in polar and cylindrical coordinates. In spherical coordinates, the distance from the origin to the point is ρ, "rho."
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
