Question regarding holomorphic functions
  • Thread starter Thread starter Susanne217
    Functions
Susanne217
Given a complex valued function f(z) = 1/z^2+1 show the area for which its holomorphic?
I know that if f:\Omega \rightarrow \mathbb{C} and z_0 \in \Omega
then f'(z_0) = \lim_{z \rightarrow z_0} \frac{f(z)-f(z_0)}{z-z_0}
if the limit exists then f is holomorphic at the point z_0...
To show the area for which f is holomorphic isn't this simply to check if the definition above can be applied to every z_0 of f?? Or am I missing something here?
where the two possiblites for z_0 = \pm i or is it simply that f is holomorphic on the area \Omega - \{\pm i\} ??
Best Regards
Susanne
First, is that (1/z^2)+ 1= \frac{1}{z^2}+ 1 or 1/(z^2+ 1)= \frac{1}{z^2+ 1}[/itex]?<br /> <br /> The first is not defined at z= 0 and the second is not defined at z= i or z= -i.
<br /> <br /> HallsofIvy its suppose to to be <br /> <br /> f(z) = \frac{1}{z^2+1}<br /> <br /> Isn&#039;t the point being here that the holomorphic definition can be applied to every point in \Omega except \pm i ??
Isn't the point being here that the holomorphic definition can be applied to every point in \Omega except \pm i ??
By that I mean that according to the definition of holomorph then a function can only be called holomorphic iff its complex differentiable in all points...
But since f&#039;(z_0 = \pm i) doesn't exist then as I understand the definition of Holomorphic functions that f is holomorphic \forall z_0 \in \mathbb{C} \setminus \{\pm i\}
Because (\frac{f}{g}^{\prime})(z_0) = 0 then z_0 = \pm i and hence the definition of Holomorphic doesn't apply then z_0 = \pm i. Then the area for which f is holomorphic is \forall z_0 \in \mathbb{C} \setminus \{\pm i\}.. As I see it...
where \Omega(z_0,r) where r>0 with the exception above is the area for which f is holomorphic...
How is that Hallsoftivy??
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
