Questions about parallel plate size
The discussion revolves around calculating the size of parallel plates for a capacitor designed to store 1 kWh of energy at 50 kV. The initial calculations suggest a plate area of 0.00048 square meters, which seems small for the energy capacity. Participants clarify that the large separation between plates allows for storing significant energy with minimal charge movement. The correct formula for calculating the area of the plates is emphasized, and discrepancies in calculations are noted, suggesting a need for careful review. Overall, the conversation highlights the complexities of capacitor design and the importance of accurate calculations in electrostatics.
Christofferall
Questions about parallel plate size...
Hi everyone, new member here and I apologize in advance if my questions seem somewhat amateur.
Recently I've started learning about capacitors, electrostatics and electric theory in general. I guess I'm having trouble trying to wrap my head around the actual area (size) of the plates of a parallel capacitor. For instance...if I want to size a capacitor that has the charge of 1kwh...(3,600,000 joules), at 50 kv, the equations say I would need a cap size around .00288 farads.
When I try to calculate the area of the plates for a .00288 cap with .5 meter separation, a dielectric permittivity of 3...I get a plate area size of .00048 meter square.
This seems like an awfully small plate size to hold that amount of energy.
I guess I'm just looking for some validation to my answers, and if not maybe someone could point me in the right direction. Thanks for your replies in advance.
Welcome to PF;
None of those are units for charge. You want the cap to be able to store 1kWh of energy?
i.e. it should cost you 1kWh to charge it up.
But the plates are a long long way apart - so you don't have to move much charge for that energy.
It is like, if you wanted to store energy in gravity, then you can move a small amount of mass up a long height or a lot of mass up a short height.
So it is with charges - you can store the same energy moving a little charge a long way or a lot of charge a short way.
At 50kV - would you be able to get a spark to jump the 50cm gap in vacuum?
However ... I'd like to see you check the actual calculation step by step.
The energy stored in a parallel-plate capacitor, with a vacuum separation, would be given by:
$$U=\frac{1}{2}\frac{\epsilon_0 A}{d}V^2$$
ref: http://en.wikipedia.org/wiki/Capacitor#Parallel-plate_model
Thanks for your reply Simon.
I was using the formula U=1/2cv^2 to find the needed capacitance.
3,600,000=1/2C50,000^2
3,600,000/1/2=>7,200,000
7,200,000/50000^2=>C=>.00288 in farads
I thought this is telling me the needed capacitor size in farads if I know the amount of energy I want stored in joules (3,600,000) at 50 kv.
From there, knowing the capacitor size in farads, I wanted to calculate the actual plate size needed for a cap rated at .00288 farads.
Not using vacuum in the gap, we'd be using a silicon oil...transformer oil. Say the permittivity is 25, dielectric constant 2.7. This is rated up to 50 kv...probably wouldn't charge the cap to the max but just using it for an example :)
Thanks again.
That's right - and the capacitance is C=εA/d in the parallel-plate model.
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/pplate.html
Combining these two equations gives you: $$U=\frac{1}{2}\frac{\epsilon_r\epsilon_0 A}{d}V^2$$ ... cutting out the middleman - so to speak ;)
A permittivity of 25 seems rather large but I don't see the units ... perhaps you mean "relative permittivity" ##\epsilon_r=25##?
I notice you did not show your calculation step-by-step, so I cannot tell what you did.
You want to find area A given everything else ... which is:
$$A=\frac{2Ud}{\epsilon_r\epsilon_0 V^2}$$
Using:
U=3600000J
V=50000V
d=0.5m
εr=25
ε0=8.85x10-12F/m
... I get a different number to you.
This is why I suggested you go back over your calculation carefully - did you miss something out or use a different formula for capacitance or something?
When Tesla needed high voltage condensers for his trans-Atlantic transmitting station, he had long barns constructed, the height of two-storey houses, and filled them with metal panels hanging vertically from the ceiling to form air-spaced condensers. The panels were kept in place with, I think, glass insulators and separators.
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
