Questions about turbulence spectra
  • Thread starter Thread starter RandomGuy88
    Spectra Turbulence
Measuring 2D turbulent flow with a split film probe allows for velocity data in the x and y directions, leading to questions about energy spectra derived from these measurements. The energy spectrum is obtained through the Fourier transform of spatial correlations, while the power spectral density (PSD) of total instantaneous velocity includes a nonzero DC component. Although both methods may yield similar results, the normalized values differ. When using a single probe at a fixed location, the PSD provides energy as a function of frequency, and invoking Taylor's hypothesis is necessary to expect a -5/3 slope in the inertial range. This approach is generally valid if the turbulence is sufficiently developed.
RandomGuy88
I am measuring a 2D turbulent flow using a split film probe. This gives a time history of the velocity in the x and y directions. I have a few questions about obtaining energy spectra from these measurements that I am hoping someone can help me with. The energy spectrum of the turbulent flow is acquired by taking the Fourier transform of the spatial correlation between the fluctuating components of the flow. This gives energy as a function of wave number (length scale).
My first question is: How does this compare to taking a PSD of the total instantaneous velocity (not the fluctuations)? Does a PSD of the instantaneous velocity provide the same information as the energy spectrum of the fluctuations? Can I still expect to see a slope of -5/3 in the inertial range?
Second question: In my experiment I am using a single probe at a fixed location. So I am not able to measure spatial correlations. So by taking the PSD I am actually getting the energy as function of frequency. So can I still expect to see a slope of -5/3 in the inertial range or do I have to invoke Taylor's hypothesis?
Thanks
What is a PSD? The power spectral density, I guess.
The primary difference would be the fact that the total instantaneous velocity would have a nonzero DC component, while the fluctuations would not. Otherwise they should produce the same answer, though the normalized values would be different I suppose.
Keep in mind that I did my PhD work in boundary-layer stability, not turbulence, so I have a lot of experience with power spectra but am still relatively new to turbulence. However, I believe you technically must invoke Taylor's hypothesis, but it is generally a very good approximation in these situations and you end up seeing that -5/3 slope pretty frequently provided that the turbulence is sufficiently developed.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
