What Are the Three Basic Formulas in Physics?
  • Thread starter Thread starter Physics_n00b
    Formulas
Physics_n00b
Can you tell me the 3 basic formulas? I forgot them. The ones with
V=
Vi-Vf=
D=
I don't have any idea. What do you suppose V and D are? Velocity and distance?
Never mind I got them.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
