Dimension & Linear Maps: Does U=V?
  • Thread starter Thread starter FunkyDwarf
    Dimension Linear
FunkyDwarf
Hey guys,
Does dimension remain unchanged under a linear map? Ie if i have a map f:U->V does dim(U) = dim(img(f))?
Cheers
-Z
Not necessarily.
For a trivial example, take the zero map on a space of positive dimension.
Something that might be of interest to you is the rank-nullity theorem.
Yeh i kinda figured it didnt hold. Actually i was going to use it to prove the RL theorem if it was true
cheers
Z
If L is linear, L(U) cannot have dimension higher than U. It can have dimension lower than U. Of course, to do that, L must map many vectors to the 0 vector: its kernel is not empty. The "nullity-rank" theorem morphism mentioned says that the dimension of L(U) plus the dimension of the kernel of U is equal to the dimension of U.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
