Define R/Q: How to Add in Quotient Groups
matness
how to define R\Q?(under addition)
R\Q={a+Q:? <a<?}
a€R but if it is not bounded then it will repeat
please help me
n
you define [x]+[y] to be [x+y] wehre [z] means the equivalence class of y (ie the coset y+Q)
quotient group is the set of cosets y+Q but if i take y€R the sets begin to repeat (it is a cyclic group, isn't it?)i
for example R\Z ={x+Z: 0<x<1} is set of disjoint sets
so can we also find conditions for y to be disjoint and nice?
of course the groups isn't cyclic, it isn't even countable os can't have a singel generator. i struggle to understand your question. what "sets" begin to repeat? plus all cosets are disjoint or equal. do you simply want a "nice" way of describing the equivalence classes? i doubt there is one.
mattgrime:<do you simply want a "nice" way of describing the equivalence classes?>
probably. sorry for misremembering the defn for cyclic groups
what i want to know is a description for set of disjoint (but not same) cosets such that their union is real numbers.
the R\Q question crossed my mind because of the description R\Z ={x+Z: 0<x<1} if x were bounded as 0<x<2 some of the elements of the R\Z would be same That is what i mean by "repetition".
but i could'nt describe a set for R\Q in the same way
All of these seemed to me related to counting. when counting real numbers(it is a bit utopian) adding a number € Z and a real number between 0 and 1 is enough. (e.g. 3.4=3+0.4 and this representation is unique using this method)
but same method using rational numbers does not work ,
can we say adding a number € Q and an irrational number between 0 and 1 is enough .
(a real number is more than enough)
thanks in advance
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
