What is the wavelength of the radiation emitted at transition 3?
The discussion revolves around calculating the wavelength of radiation emitted during transition 3 in an atom's energy state diagram. The user initially attempted to find the wavelength by subtracting the wavelengths of transitions 1 and 2, resulting in an incorrect answer. It was clarified that the correct approach involves converting the wavelengths to energy, finding the difference between the energies of the transitions, and then converting back to wavelength. This method led to the correct answer of 162 nm for transition 3. The user expressed gratitude for the guidance and confirmed understanding for future calculations.
mstud
The figure (see attachment) shows part of a energy-state-diagram for an atom. Three energy states are included. At energy transition 1 & 2 the atom emit radiation with the wavelengths of 2.56 \cdot 10^{-8} m and 3.04 \cdot 10^{-8} m, respectively.
Find the wavelength for the radiation which is emitted at transition 3.
N/A
I tried to take wavelength 1 minus wavelength 2, but this gave a completely wrong answer.
I got 4.8 nm. But the answer should be 162 nm.
How shall I then solve it? Does it make any difference to calculate the energy of the two transitions and find the difference between them, or will that give me the same weird answer?
ANY ideas?
Thanks
N/A
ANY ideas?
Thanks
You can only subtract energy - the difference between energy levels.
You need to convert the wavelengths to energy, subtract the energies, then convert the answer back to a wavelength
Thought of doing so but I didn't know if it was the right way.
Thank you , know I both got the right answer and know how to do it next time ...
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
