Converting the Speed of Light into Micrometres/Year for Radical Equation Problem
  • Thread starter Thread starter Stratosphere
    Radical
The discussion revolves around solving a radical equation related to the speed of light, specifically converting it into micrometres per year. Participants suggest simplifying the equation by dividing both sides before squaring, and clarify the correct notation for the speed of light in the equation. There is a focus on using the constant 'c' for the speed of light instead of converting it prematurely, which could lead to complications. The conversation emphasizes the importance of correct mathematical notation and unit conversion in relativity problems. Ultimately, the goal is to find a manageable way to express the speed of light in different units while maintaining accuracy.
Stratosphere
86300=\frac{86400}{1/\sqrt{1-(v/299000000){2}}}
When I square each side I get an astronomicly high number.
hi stratosphere
have you tried dividing both sides by 86400 first?
Or, better, dividing both sides by 86300 and then multiplying both sides by that square root.
And, is that
\sqrt{1- (v/299000000)2}
supposed to be
\sqrt{1- (v/299000000)^2}?
HallsofIvy said:
And, is that
supposed to be
Yah I meant to make it an exponent.
If you're attempting to use the relativity equations (I'm guessing to find length contraction?), rather than using metres/second for the speed of light and resulting in astronomically high numbers, or better yet, converting the speed of light into micrometres/year; why not just leave it as c, and after solving for c, substitute whatever unit of measurement you want in place for it.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
