Calculating Wavelength of Radio 4 FM & Explaining Loss in Deep Valleys
The wavelength of Radio 4 FM, transmitted at 92.5 MHz, can be calculated using the formula wavelength = speed of light / frequency, resulting in approximately 3.24 meters. In deep valleys, the terrain obstructs radio waves, leading to significant signal loss due to diffraction and reflection. The shorter wavelength of FM signals makes them less capable of bending around obstacles compared to longer wavelengths. Consequently, listeners in these areas experience difficulty receiving the broadcast. Understanding these principles is crucial for addressing radio reception issues in challenging landscapes.
manjula
Radio 4 transmits on FM at a frequency of 92.5 MHz Calculate the wavelength and use it to explain why listeners in deep valleys cannot pick up radio 4 FM.
First of all what is the wavelength.
If you don't know that you might really not know where to start.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
