Radio waves vs material & shape
Radio waves around 1900 MHz, like those used by cell phones, cannot pass through a solid aluminum box due to the metal's properties, which act as a Faraday cage. To improve signal transmission, creating a hole in the box can allow some waves to escape, but the size and shape of the hole are crucial; ideally, it should be about half the wavelength of the signal. A non-conductive coating on the aluminum may not significantly enhance signal transmission, as the metal will still reflect most waves. Overall, the more metal surrounding the phone, the worse its performance will be. For optimal results, consider the dimensions of any openings to facilitate better signal escape.
bikespot
What happens when radio waves of around 1900mhz (cell phone) is confined in an aluminum box. Will the waves be able to pass through the box to the outside.
What would be the best way to get the waves to the outside of the box with only modifying the box. If i cut a hole would that improve how much signal is escaping the box . Also depending on the size of the hole and the shape. What about a non conductive coating on the aluminum...
Science news on Phys.org
Would the waves just bounce off the walls of the aluminum box. What if there was a hole in the box.
Basiclly I am trying to still have the aluminum box but have as much signal pass through it as possible.
Your cellphone will work with much reduced performance in a box with an opening--basically the more metal you put around and near it, the worse it will perform. If you need a mostly-enclosed box, then add a slot that is onehalf the wavelength λ. This will act as a radiator (antenna) that will permit some radiation to escape. You can compute wavelength from frequency as \lambda=\frac{c}{f} where f is the frequency and c is the speed of light. Since you are perturbing the phone antenna's by putting metal near it, and since the slot is in its near field region, I wouldn't expect very good performance.
bikespot..
Faraday cages are used to block electromagnetic radiation and protect interior electronics..even from lightning strikes...you might find this discussion of Faraday Cages of interest...has some practical insights
http://en.wikipedia.org/wiki/Faraday_box
while they discuss exterior electromagnetic waves, obviously internally generated waves are blocked/transmitted similarly.
A solid metal box should not allow electromagnetic waves to escape unless the metal is too thin like a coating or something. If you make a hole or holes in the box whose size is much larger than the wavelength then the waves can escape.
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
