Radius of Curvature at Soap Bubble Contact Point
The discussion focuses on determining the radius of curvature at the contact point between two soap bubbles of different radii, r and R. Participants emphasize the role of surface tension in the problem, noting that while it is relevant, it ultimately cancels out in the calculations. The key approach involves applying the pressure difference formula, considering the internal pressure of the bubbles and the common radius at their point of contact. One participant successfully arrives at the answer after guidance, while others express confusion about the concept of common radii. The conversation highlights the importance of understanding pressure dynamics in bubble interactions.
vkash
Two soap bubbles of radius r and R are in touch find the radius of curvature of their point of contact?
(Both bubbles are touching each other with their external surfaces)
I have no idea about this question. can you please try to help>
What do you know about surface tension?
No info about surface tension. even answer is in terms r and R.
If you think it can't be done without data related to surface tension then assume that to be S.
answer in book may be wrong...
So do you know the answer?
yeah;
It's answer is given in book. But book doesn't provide procedure.
Surface tension does come into it but in this problem it cancels out.Have you studied surface tension?
yes. (I have read surface tension,angle of contact, capillarity, pressure inside a soap and liquid bubble,change in energy when surface expand or collapse).
How do you approach to this question?
Good,so you should know that the pressure inside a bubble is greater than the pressure outside.Now apply that pressure difference formula to the bubbles when they are in contact.There are three radii of relevance r,R and the common radius over their area of contact.
Wow!
great;
i have got the answer.
thanks for helping me.
vkash said:
Wow!
great;
if u have understood pls help me too i haven't understand nythin abt the common radii
