Random Thoughts 7
- Thread starter Evo
- Start date
2,061 replies · 125K views · last reply
- 4,509
That's pretty good life for the commonly used frames.WWGD said:Thanks. Well, at least I got my 8.5 years' worth of it. I bought it on January 2016.
If you want longer life, get your doctor to prescribe "Industrial Safety Glasses." Here in the US, they are normally worn in industrial jobs, think machine shops and the like. Both the frame and lenses are much sturdier and substantial. The lenses are guaranteed not to shatter when hit with a steel ball dropped from 40 feet! (A Federal requirement here)
Every now and then I end up using a grinder or power saw to cut metal, so I always get Safety Glasses with Glass lenses. These days, plastic lenses are more common, but they tend to pit when sparks from a grinder hit them.
As of this writing, there seem to be only one or two labs in the country that can supply the glass safety lenses; you may have to spend time on the phone finding an optician that deals with an appropriate lab.
Those screws typically have the end of the threads deformed after assembly so they don't come loose and fall out. Often, if you look, you will find a small dimple in the end of the screw deforming the threads. Most of us do not have the tooling to repeat that after disassembly.Jonathan Scott said:If it is possible to release the lens on that side temporarily by unscrewing one or two tiny screws in the hinge of the arm, you may be able to wrap some tape (say insulating tape) around the side of the frame and also around the bridge to hold it together, then put back the lens.
Cheers,
Tom
skyshrimp
- 39
- 122
I’m a fan of ALDI Vive diet cola. It has a nice spearmint taste to it. I wish there was a caffeine free version.
Homework Helper
- 7,926
- 13,238
Strangely, I was looking for a way of putting caffeine on a cola that didn't have any. It seems there's powdered caffeine available at some " Chemists", as the recommender, who must be either British( only ones I've heard call it that) or around 100 years old.skyshrimp said:I’m a fan of ALDI Vive diet cola. It has a nice spearmint taste to it. I wish there was a caffeine free version.
- 4,509
Approach #6WWGD said:Tried 5 ways of correcting for my WhatsApp phone to allow sound from my side to the others, as I could hear others when they called me, but others couldn't hear me. None of them worked.
Not familiar with what it is, but if it is a physical device here is an approach that will likely work:
1) Take it to where you got it
2) Tell them it doesn't work
3) and that you want your mony back if they can't fix it
Homework Helper
- 7,926
- 13,238
The warranty expired a few months back; I've had it since January 2023. I suspect I may have damaged a microphone when I dropped it.Tom.G said:Approach #6
skyshrimp
- 39
- 122
I Googled caffeine powder and was surprised at how much it costs considering how it’s mass produced.
I’ve been playing with AI.
Mayhem
- 456
- 336
Academia will trick you into thinking you are stupid unless you do a Ph.d while most people think radiowaves are on par with ionizing radiation.
Homework Helper
- 7,926
- 13,238
A Far aday ( Cage) keeps the hackers away.
Will look into buying a RFID blocking slip for the wallet. Seems there are too, wallets made of protective material and which carry chips that can communicate with a mobile phone. Others have bluetooth or Gps trackers.
This post brought to you by Paranoia.
skyshrimp
- 39
- 122
I fancy a tandoori chicken masala with a peshwari naan, a tandoori mixed grill, pilau rice and meat samosas with mint sauce, but I'm fasting. I started 4 hours and 10 minutes ago.
Homework Helper
- 7,926
- 13,238
Visualize roadkill to have your fasting go more smoothly.skyshrimp said:I fancy a tandoori chicken masala with a peshwari naan, a tandoori mixed grill, pilau rice and meat samosas with mint sauce, but I'm fasting. I started 4 hours and 10 minutes ago.
Mayhem
- 456
- 336
It means Christmas in French (Noël)WWGD said:Isn't the name ' Noel' ( No L) self-contradictory?
- 10,069
Last night I was dining with strangers and the discussion was a lot about personal growth, knowing oneself, and such. It then took a sudden turn towards astrology and numerology.
You know "What's your number? Just add the ones from your birthday and find out who you are." There were some strong believers. Then you have people sort of agreeing with them (Are they just being polite?) and you just don't know how to get into that discussion without insulting everybody.
But I just thought of something.
With the decimal system, "your number" basically always ends up being between 1 and 9. (They apparently introduce complications with "master numbers"
What if I suggested using the binary system instead? Reducing any number by summing up its constituents will always lead to 1! Wouldn't it be great to all be unified by numerology? We are all number 1!
Homework Helper
- 7,926
- 13,238
I'm a Gemini, and we Gemini don't believe in Astrology.jack action said:Last night I was dining with strangers and the discussion was a lot about personal growth, knowing oneself, and such. It then took a sudden turn towards astrology and numerology.You know "What's your number? Just add the ones from your birthday and find out who you are." There were some strong believers. Then you have people sort of agreeing with them (Are they just being polite?) and you just don't know how to get into that discussion without insulting everybody.
With the decimal system, "your number" basically always ends up being between 1 and 9. (They apparently introduce complications with "master numbers")
I sometimes through such exchanges with bizarre questions that throw people of: " Cardi B, or Car Db? Is it a database of used cars? " or " Didn't cuba just invade Argentina?" Sometimes I just do it , though unintentionally.
Staff Emeritus
2025 Award
- 22,729
- 7,832
https://www.yahoo.com/lifestyle/fanwood-wwii-veteran-103-shares-100142949.htmlAt nearly 103 years old, World War II veteran Joe Schott said he believes he has a lot of service ahead of him.
Schott remembers back to 1942, only a year or two after he finished high school. He was working with Western Electric in Kearny at the time, testing sound-powered telephones and other equipment to be used on Navy ships.
"Western Electric kept telling me that due to the nature of my work, I would be deferred from the draft. I'd be more valuable working at Western on the things I did. I would transfer that information to the man at the draft board, and I remember him saying to me, 'Don't believe them. You will go in!'
"So, sure enough I did get word that I would be drafted [into the Army]. I was just about to be. So on a Sunday morning I went to the Navy recruiting office station at the post office in Newark. They were open seven days a week. I remember going there, and I sat down at the desk. There was a man, and I showed him the letter I got about the draft, and I said, 'I'd rather go in the Navy.' And I remember he looked up at me and he said these words: He said, 'You're in the Navy now.'"
Well done, sir!
Homework Helper
- 7,926
- 13,238
I've done searches for movies, just to get results from movies that had played years prior. Just who would be interested in any such thing? I've essentially given up google for ChatGpt. I guess SEO's don't help either.Borg said:Doing research on a vacation and saw a popular tourist area on Google Street View that was eerily empty with all of the stores closed. Then I looked at the image date and saw that it was June 2020 during the pandemic. Seems so long ago sometimes.
- 13,942
- 16,862
When we bought our house its garage door was dark blue and in some disrepair, with one of the panels actually half out of place. We replaced the whole door with a white one fairly quickly after we moved in.Borg said:Doing research on a vacation and saw a popular tourist area on Google Street View that was eerily empty with all of the stores closed. Then I looked at the image date and saw that it was June 2020 during the pandemic. Seems so long ago sometimes.
The garage looks along our road. When Street View next updated the photos must have failed at one spot or something, because for a while if you moved the viewpoint along our road you saw our shiny white garage door on a sunny day suddenly change into the old blue broken down door on a dark grey day, then flip back to white and sunny. It's updated again since, but it was surprisingly creepy while it lasted.
- 5,281
I had a similar thing with the regular map view. I always parked a red SUV that I used to have in the garage. There was a single day once where I was working in the garage and parked it across the street. That was on the map for a few years until it updated.
Homework Helper
- 7,926
- 13,238
Wonder if google maps bleeps out security details from its maps.Ibix said:When we bought our house its garage door was dark blue and in some disrepair, with one of the panels actually half out of place. We replaced the whole door with a white one fairly quickly after we moved in.
skyshrimp
- 39
- 122
I like a cold pint of Guinness. It's apparently good with a drop of blackcurrant cordial.
- Evo
- · Replies 11K ·
- Other Physics Topics
- Replies
- 11K
- skyshrimp
- · Replies 5 ·
- Replies
- 5
High School
Random thoughts on Fibonnacci sequence
- parshyaa
- · Replies 4 ·
- General Math
- Replies
- 4
- Raghav Gupta
- · Replies 8 ·
- Biology and Medical
- Replies
- 8
- ThomasT
- · Replies 25 ·
- Electromagnetism
- Replies
- 25
- Cait
- · Replies 1 ·
- Astronomy, Astrophysics, Cosmology
- Replies
- 1
- Fra
- · Replies 3 ·
- Quantum Interpretations and Foundations
- Replies
- 3
- kyphysics
- · Replies 52 ·
- Replies
- 52
- EternalStudent
- · Replies 1 ·
- STEM Academic Advising
- Replies
- 1
Undergrad
Random thought about force and motion
- tadpole
- · Replies 7 ·
- Mechanics
- Replies
- 7
