Equilibrium Reactions: Not All Elementary?
In summary: So even if you can't come up with a physically reasonable mechanism that makes sense both ways, you can still use the equilibrium equation to work out the equilibrium of a reaction.
IAmUnique
The rate law is given by R=k[A]^m[ B]^n where m,n needn't be equal to stoichiometric coefficients...but we use r=k[A]^a[ B]^b where a,b are stoichiometric coefficients when we use ratio rate of forward to rate of backward reaction in getting value of equilibrium constant K for any given reaction at equilibrium...why is it different in both cases...does it mean all equilibrium reactions are elementary reactions? But that isn't possible as many intermediate steps are equilibrium reactions in the mechanism of complex reactions...
Chemistry news on Phys.org
No. It is kind of a coincidence that it works this way.
Well, it's a coincidence for all reactions in equilibrium sounds peculiar...
Like I said a complex mechanism too can be in equillibrium...in that case the rate law equation should have different coefficients...but all problems we solve in equillibrium chapter have stoichiometric coefficients only
t
Equilibrium can be derived from the thermodynamics, then it is clear why it follows the reaction stoichiometry. As you have correctly said, reaction kinetics doesn't follow stoichiometry - or rather, it sometimes follows stoichiometry of the elementary reactions (which are not necessarily the same as the forward and/or backward reaction). For such simple cases kinetic approach yields the same formula for the equilibrium - no coincidence here. Generalization of that approach yields the same result as the thermodynamics, but is a coincidence in the sense that the generalization is incorrect.
We have discussed this quite often here including quite recently, so briefly - you can derive the equilibrium laws from quite general thermodynamic arguments (found in all University level starting textbooks of physical chemistry) and so whatever mechamism and rate law, the equilibrium law has to be obeyed. So given a rate law fornthenforward reaction you can deduce that for the back reaction.
I think you could not come up with a mechanism that made sense in both directions for which you didn't get the right equilibrium law, but you are welcome to try - it might ba the best way to convince yourself and understand.
There is a physical principle you have to incorporate into this - that is that the path of the reverse reaction is the same as the forward reaction in reverse - you can't go back another way. If you could then indeed you don't generally get the ordinary equilibrium equations. But classical and quantum mechanics say that this 'principle of microscopic reversibility' aka 'detailed balance' is true.
1. What is an equilibrium reaction?
An equilibrium reaction is a chemical reaction in which the forward and reverse reactions occur at the same rate, resulting in no net change in the concentrations of reactants and products over time. This state of balance is known as chemical equilibrium.
2. How do you determine if a reaction is at equilibrium?
A reaction is at equilibrium when the concentrations of reactants and products remain constant over time. This can be determined by analyzing the reaction's rate, which will be equal in both the forward and reverse directions at equilibrium. Another way is by observing the physical properties of the system, such as color or pressure, which will also remain constant at equilibrium.
3. How do equilibrium reactions differ from elementary reactions?
Equilibrium reactions involve multiple steps and can have intermediates, while elementary reactions occur in a single step and have no intermediates. In equilibrium reactions, the concentrations of reactants and products are constantly changing, while in elementary reactions, the concentrations of reactants and products are only changing during the reaction. Additionally, equilibrium reactions are reversible, while elementary reactions are not.
4. Can equilibrium reactions be manipulated?
Yes, equilibrium reactions can be manipulated by altering the concentrations of reactants and products, changing the temperature, or adjusting the pressure. This can shift the equilibrium towards the reactants or products, changing the equilibrium constant and ultimately changing the direction of the reaction.
5. How are equilibrium reactions important in everyday life?
Equilibrium reactions play a crucial role in many everyday processes, such as in the production of ammonia for fertilizers, the formation of carbonic acid in soda, and the regulation of pH levels in the human body. They also help maintain the balance of gases in the Earth's atmosphere, ensuring the survival of living organisms. Understanding and controlling equilibrium reactions is essential in various industries, including pharmaceuticals, agriculture, and environmental science.
  • Chemistry
