Rate of decrease of the magnetic fields
The discussion focuses on the mathematical derivation of the rate of decrease of magnetic fields, denoted as V_B. It begins with the relationship between the electromotive force (EMF) and the rate of change of magnetic flux, expressed through the equation involving the integral of the electric field. The magnetic flux is defined as the product of area and magnetic field, with the area remaining constant while the magnetic field changes over time. The analysis shows that the combined magnetic flux from two regions, with opposing directions, leads to a derivative that results in a specific expression for the EMF. The conversation highlights the importance of clarity in problem description and adherence to discussion guidelines.
Oblakastouf
Let V_B be the rate of decrease of the magnetic fields
\frac{dB}{dt}
For the 3rd path:
\oint E\cdot ds = -\frac{d\phi _B}{dt} = -\frac{{d\phi _B}_1 + {d\phi _B}_2}{dt}
\phi _B_{(t)} = A_{(t)}B_{(t)}
The area is constant, it's only the magnetic field that's changing:
\phi _B_{(t)} = \pi R^2(B_0 - V_Bt)
Since B1 and B2 are in opposite directions, give one of them a minus sign:
{\phi _B}_1 + {\phi _B}_2 = \pi R_1^2(B_0 - V_Bt) - \pi R_2^2(B_0 - V_Bt) = \pi (B_0 - V_Bt)(R_1^2 - R_2^2)
Take the derivative of that:
\frac{{d\phi _B}_1 + {d\phi _B}_2}{dt} = -\pi V_B(R_1^2 - R_2^2)
And therefore:
\oint E\cdot ds = \pi V_B(R_1^2 - R_2^2)
We appreciate that you know latex, but the title is useless, and you didn't follow the template. You also don't describe the problem. Don't expect an answer.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
