What is the image distance for a concave mirror using the mirror equation?
The discussion focuses on calculating the image distance for a concave mirror using the mirror equation. Given an object distance (do) of 2 cm and a focal length (f) of 4 cm, the calculation leads to an image distance (di) of -4 cm. A negative image distance indicates that the image is virtual and located behind the mirror, which aligns with the sign convention used. Participants confirm that a negative result for image distance is acceptable in this context. The conclusion affirms the understanding of virtual images in concave mirrors.
toothpaste666
B) Using the mirror equation, find the image distance.
1/do + 1/di = 1/f
[/B]
B)
do = 2cm f = 4cm
1/do + 1/di = 1/f
1/di = 1/f - 1/do
1/di = do/f(do) - f/f(do)
1/di = (do-f)/(f*do)
di = (f*do)/(do-f) = (4cm * 2cm)/(2cm - 4cm) = (8cm^2)/(-2cm) = -4cm
di = -4cm
is it ok that my image distance came out negative? if i am correct this is fine if the image is behind the mirror
It is correct, the distance of a virtual image is negative in the frame of sign convention you applied.
Likes toothpaste666
thank you!
