Is Bulb B the Brightest When the Capacitor Has Half its Maximum Charge?
Bulb B is determined to be the brightest when the capacitor has half its maximum charge, which results in a potential difference of 55V across the capacitor. At maximum charge, the capacitor acts like an infinite resistance, leading to zero current in the circuit containing bulb C. When the capacitor is at half charge, the voltage across it is halved, allowing for a higher voltage across bulb B. The calculations confirm that with the capacitor at half charge, more current flows through bulb B compared to bulb A. This analysis supports the initial assumption regarding the brightness of bulb B under the specified conditions.
hawkbyte
SOLVED - RC Circuit - Question
http://img291.imageshack.us/img291/5585/bulbd.th.jpg
This problem is giving me a headache. I feel certain that bulb B is the brightest when the capacitor has half its maximum charge. However, I am having a hard time coming up with equations for the circuit using Kirchhoff's voltage and current laws.
I do know that if the capacitor had its maximum charge then there would be no current in the right hand circuit. But I am a little unsure what is going on under the declared condition. I suspect that there is no current in the closed circuit that includes bulb C. And the fact that the capacitor has half its maximum charge means that the potential difference is 55V across the capacitor.
I would love a nudge in the right direction... I am stuck. Cheers!
Welcome to PF, Hawkbyte. You have an interesting question. Yes, ignore bulb C - it is shorted out. You'll have to figure out the charge on that capacitor to be sure of your answer. I see the capacitor taking a high current initially, gradually charging up and the current gradually diminishing to zero. At that point it has its max charge and it is easy to calculate because the capacitor acts like an infinite resistance. From the V, you can figure out the C. Then reverse that to get the V when the C is halved.
Since the capacitor is at 50% of its maximum charge, then the potential difference across its plates is 55V. Does that mean that I would apply that 55V to the entire closed loop that contains bulb A and the capacitor? Would I treat bulb A as a resistor in series with C? Again, the geometry of this circuit is confusing me.
I am not after exact values, I just want to see hard evidence of the fact that more current is moving through bulb B.
At FULL charge, zero current, the voltage across the capacitor is 55.
That is Q = CV = 55C. Half charge is 27.5*C. So the voltage across the capacitor (and bulb A) is V = Q/C = 27.5*C/C = 27.5. That leaves a higher voltage across bulb B so your intuition was right on.
Aye, aye... thanks very much for your assistance!
