Reading a signal off of one wire?
When measuring a 120VAC wall socket with an oscilloscope probe without a ground reference, a 60 Hz sine wave with approximately 35Vrms is observed, likely due to capacitive coupling. Connecting the probe's ground reveals the expected 120V 60Hz sine wave. The oscilloscope essentially measures the voltage difference between two points, and without a ground, it picks up ambient signals through capacitance. If the oscilloscope is battery-powered, the readings reflect capacitance between the internal ground and external sources. This phenomenon highlights how nearby electrical fields can influence measurements in open circuits.
Evil Bunny
When I put an o-scope probe into my (120VAC) wall socket, with no ground (reference) attached, just a single wire, I get a perfect 60 Hz sine wave, with about 35Vrms magnitude.
When I plug the o-scope probe into the socket with the ground attached appropriately to the return of the same socket, I get the 120V 60Hz sine wave as expected.
Why do I get the perfect sine wave (with the smaller magnitude) with no reference attached? Is it capacitive coupling?
The reason I ask this is because I was chasing down a signal today at work on some equipment and was receiving this signal (unexpectedly) off of a circuit with a known open conductor... This got me to thinking about why.
Hope that made sense.
Your body (or even a piece of wire, or the probe itself) is acting as an antenna and picking up the 60 Hz that's in the wiring all around you.
A friend of mine was working on a circuit and kept on getting an odd 88.5 MHz signal in his circuit, which persisted even when it was powered off. He then realized the campus radio station (which he was incidentally listening to) was at that frequency.
Ok so an o-scope is basically a voltmeter, correct?
Is it measuring a difference between two points?
If no ground (or reference or whatever) is hooked up, what two points is it measuring between?
What kind of 'scope are you using? Is it battery-powered, or plugs into the wall? If it's wall-powered with a 3-prong power cord, and the 'scope probe ground is Earth Grounded by the 'scope, then it doesn't matter much if you hook up the ground clip in this measurement, since the Hot lead in your AC Mains wall socket is referenced to Neutral (= Earth Ground at the breaker panel).
If your 'scope is floating and battery powered, then what you see displayed is due to the capacitance from the 'scope internal ground to external Earth ground (and nearby metal objects).
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
