Real Analysis - Mean Value Theorem Application
O_o
Let f: R -> R be a function such that \lim_{z\to 0^+} zf(z) \gt 0 Prove that there is no function g(x) such that g'(x) = f(x) for all x in R.
Supposed to use the mean value theorem. If f(x) is continuous on [a,b] and differentiable on (a,b) then \exists c \in (a,b), f'(c) = \frac{f(b) - f(a)}{b-a}
Assume there exists a function g(x) such that g'(x) = f(x) for all x in R. By the mean value theorem:
\exists c \in (0,x), f(c) = g'(c) = \frac{g(x) - g(0)}{x - 0}
This means \lim_{x\to 0^+} \left(\frac{g(x) - g(0)}{x} - f(c) \right)= 0<br /> \\<br /> \lim_{x\to 0^+} \left(g(x) - g(0) - xf(c)\right) = 0<br /> \\<br /> \lim_{x\to 0^+} \left(g(x) - g(0)\right) = \lim_{x\to 0^+} xf(c)<br />Since g(x) is differentiable everywhere (and hence continuous), the left side is equal to 0.
Now the right side is where I'm not completely comfortable. If it was the limit of x(fx) then it's exactly what I'm given in the question. I'm thinking since x is going to 0 from the right then c also has to be going to 0 and so the limit on the right is greater than 0, which is a contradiction.
Can anyone tell me if I'm using faulty reasoning? I'm not really looking for the correct answer if I'm wrong. I'd just like to know where the flaw in my logic is.
Thanks
You are treating c as a function of x, which is permissible provided you define the function. For a given x there might be more than one value c that satisfies g&#039;(c) = \frac{ g(x) - g(0) }{x - 0 }. Unless you specify which c to choose you haven't defined c as a function of x.
Thanks that's helpful. So if I can define a function c(x), is the following true:
If \lim_{x\to 0^+} c(x) = 0 then \lim_{x\to 0^+} x f(c(x)) = \lim_{x\to 0^+} x f(x)
And if so, does c(x) have to have any properties like being continuous or injective?
No.
Consider f(x) = 1/x, c(x) = x2.
Among other things, that depends on a theorem that says lim_{x \rightarrow a} w(q(x)) = w ( lim_{x \rightarrow a } q(x))
For that theorem to apply, w(x) must be continuous at x= a, but I don't think that q(x) must be. Look it up, under "composite limit theorem" or "limit of the composition of functions".
In addition to that theorem you'll need a theorem about the limit of a product x f(x) being the product of the limits of the individual factors.
There is a theorem about the limit of a product being the product of the limits of the individual factors. If f(x) were continuous at x= 0, what would that tell you about lim_{z \rightarrow 0} z f(z)
If \lim_{x\to 0} f(x) = L then \lim_{x\to 0} f(x)*x = \lim_{x\to 0} f(x)*\lim_{x\to 0} x = L*0 = 0
So if f is continuous at x=0 then \lim_{x\to 0} f(x)*x = \lim_{x\to 0} f(x)*\lim_{x\to 0} x = f(0)*0 = 0
So we can conclude that f isn't continuous at 0. And more generally \lim_{x\to 0} f(x) does not exist.
Yes
I'm not sure we can't conclude that. Check what the if-part of the theorem about the limit of a product says. If it only requires the limits of the individual factors exist (as finite limits) then you could conclude it.
What are the significant properties of antiderivatives as functions? Have your course materials covered that?
We haven't touched antiderivatives yet. So far we've only done the definition of derivative and associated laws (sum, product, quotient, chain rule) and theorems related to the mean value theorem (Rolle's Theorem, local maximums have a derivative equal to 0, mean value theorem, if f'(x) = 0 everywhere then f is a constant, if f'(x) > 0 then f is strictly increasing/f'(x) < 0 implies f is strictly decreasing, intermediate value theorem for derivatives, inverse function theorem).
Antiderivatives are obviously differentiable functions. What are the significant properties of differentiable functions? [Edit] Or am I confusing matters? It's g(x) that is differentiable, not f(x).
The big property I remember is that they're continuous. But the derivative itself doesn't necessarily have to be continuous.
edit: Yeah it's g(x) that is differentiable. f(x) is the derivative
Well, at least we identified some difficulties in you original line of attack.:w
I looked up the theorem on the limit of products. It only requires that the limits of the individual factors exist, not that the factors be continuous functions. So we can conclude lim_{x\rightarrow 0} f(x) does not exist.
Some thoughts (which may or may not lead to progress):
It think that once you define c(x), you can prove lim_{x \rightarrow 0} c(x) = 0
You can define c(0) = 0 so that would show c(x) is continuous at x = 0
If you apply the mean value theorem to the function H(x) = x g(x) I think you can show that if x \ne 0 then g(x) - g(c(x)) = c(x) g&#039;(c(x)) = c(x) f(c(x)). (Do that before taking any limits.) Then there is the question: Does lim_{x \rightarrow 0} c(x) f(c(x)) = lim_{z \rightarrow 0} z f(z)? In other words, can you do a continuous change of variable in function when taking a limit?
Thanks a lot, you've really helped me get my head around the issues with this problem. I'm going to work on the below and hopefully get an answer. Cheers :)
