Really simple Resistor question NEED HELP
  • Thread starter Thread starter Larrytsai
    Resistor
The discussion revolves around understanding the concepts of equivalent resistance in circuits, specifically in the context of series and parallel configurations. The original poster seeks clarification on how to determine the relationship between equivalent resistance and sources in a circuit.
  • Participants explore definitions of series and parallel configurations, questioning how these relate to equivalent resistance and voltage sources. Some seek further explanation on the criteria for classifying resistors as being in series or parallel.
The discussion includes various interpretations of the concepts, with some participants providing insights into the conditions that define series and parallel arrangements. There is an ongoing exploration of the original poster's question, with no clear consensus reached yet.
Participants reference a specific example involving resistors and a source transformation, indicating a need for clarity on the application of these concepts in practical scenarios. There is also mention of a link to an external question that may provide additional context.
Larrytsai
So i have a general question that I came across with source transformations, but this question can be classed as a beginner question.
When I find the equivalent resistance, how do you determine whether or not it is in series or parallel with a source?
when the resistors have equal voltage then they are in parallel. and when they have equal current then they are in series :)
umm can you explain a little more, I don't understand.
I don't understand how I could use that to determine whether or not my equivalent resistance is in parallel or series with sources
Your question doesn't make much sense. "Equivalent resistance" can be either in series or in parallel with a voltage source, depending on what equivalent resistance you're talking about in a circuit.
Sorry, can you look at this question http://www.cramster.com/solution/solution/727803
if you look at the 10 and 40 ohm resistor, why is it when you find their equivalent resistance, they are in series after.
oh k nvm i got it thnx.
When resistors share the same nodes they are in parallel, when they only share one common node (with no other resistances nodes sharing that common node) they are in series.
