How Does Recoil Momentum Translate to Force on a Load Cell?
The discussion revolves around calculating the force registered by a load cell after a system is set into motion by an explosive force. The user estimates the system's momentum at 11.38 kg-m/s and measures a peak force of 300 Newtons from the load cell. They seek to understand the relationship between momentum and force, particularly how the load cell's spring rate and displacement factor into the calculations. Key suggestions include measuring the force over time and using additional sensors like accelerometers for accurate data collection. The conversation emphasizes the importance of timing in experiments to derive meaningful results from the measurements.
moemag
I am trying to figure out what I am doing. Forgive me, I’m not very sharp when it comes to differential equations… or even a useful working knowledge of calculus. I understand the concepts but if I can’t figure out how to type it into my TI-89 or get Wolfram alpha to do it… I’m kind of stuck and would appreciate some assistance.
So to start:
I have a system that has a combined momentum of 11.38 kg -meters/second. At least that is what I am estimating it to be. I know the mass of the moving part, and I know how fast it is going at it's peak.
I built a test rig to hold the system, which contains a small explosive force, setting the system into motion. The system is butted against a load cell. After firing the peak force the load cell registered was 300 Newtons.
How do I get from momentum… to 300 Newton’s force?
I’m guessing it has to do with the spring rate of the load cell… which is very high. I believe the load cell only moves .127mm in its entire stroke and is good for. (http://www.transducertechniques.com/lpo-load-cell.aspx ... its LPO-5K)
I keep thinking it’s somewhere in the relationship 1/2 m*v^2=1/2 k*x^2… but I’m pretty sure that somehow I have to figure out how long it takes the spring of the load cell to de-accelerate the mass, thus producing a force… I just don’t know how to do that/express that mathematically.
-my first post... this seems like where I would put this question, forgive me if it belongs somewhere else.
u know force.. F=Kx..find "X" displacement of srping..coz k of spring is given by manufacturer..
put "X" in the eq u gave find "v" velocity..now multiply it with mass and get momentum
now at position one at time t=0 the velocity is v=max thus mometum is max..
at state two..t=T2 velocity is v2=0 thus momentum is zero..coz all the kinetic energy has been converted into spring's potential energy..
force is rate of change of momentum i.e
F=dM/dT=M1-M2/T1-T2
u have m1= max what ever the value u calculate and m2=0,u have time t1=0 and T2 can be calculated coz force is known..
but this an approx solution..
As engnr_arsalan answered: impulse, but you need to time your experiment, not simply rely on peak force. Can you chart your force vs. time?
A second sensor such as an accelerometer (acceleration) or video(position) would really be needed to confirm results. KE is not something you can rely on. You can rely on it's derivative (MV) but you need a way to time things.
Thanks!
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
