Recrystallizing but not getting any crystals
  • Thread starter Thread starter JG89
    Crystals
The discussion revolves around the challenges of recrystallizing lidocaine HCl from methanol. The user initially created a saturated solution but experienced no recrystallization after cooling and placing it in a water bath. Upon evaporating the methanol, they were left with a transparent, gooey substance instead of crystals. It is noted that obtaining an oily residue instead of crystals can occur with rapid evaporation. Suggestions include ensuring the solution is supersaturated, allowing more time for crystals to form, and possibly adding crude lidocaine as a seed to promote crystallization. Additionally, exploring different solvents or solvent mixtures for recrystallization is recommended, as certain salts of organic compounds can be difficult to purify.
JG89
I am trying to recrystallizing lidocaine out of methanol. I created a saturated solution of lidocaine and hot methanol, waited for it to cool to room temperature, then threw it in a cool water bath. There was no recrystallization. I decided to evaporate the methanol to recover my lidocaine and start over again, but after evaporating the lidocaine in a hot water bath, I was left with a transparent gooey substance in my beaker. Usually when I dissolve something into a solvent and evaporate off that solvent, crystals will form (even though they may not be pure). What happened here? And how can I recover my lidocaine?
EDIT: Just to be clear, this is lidocaine HCl.
Chemistry news on Phys.org
Getting an oil instead of crystals is very common, especially on rapid evaporation.
Are you sure your solution was supersaturated? Sometimes you have to wait for days until crystals form, so you could leave your solution for some time in the fridge and see what happens. You could also add a small amount of crude lidocaine to your solution to act as a seed.
Another thing to check out is that certain salts of organic compounds are not always the easiest to prepare and subsequently purify, for any number of reasons. If you just need a pure lidocaine salt, you might want to switch it up and make your life easier if the hydrochloride salt continues to be ill-behaved.
I presume you checked the suitability of various solvents/solvent mixtures for recrystallizing lidocaine - if you haven't, that's something that should be done as well.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
