A Reference frame conversion for a moving sphere
Estimating the total kinetic energy of a spherical particle using a MEMS sensor involves calculating both translational and rotational components. The sensor provides angular velocity data but lacks linear velocity, necessitating an integral of acceleration, which is complicated by noise and drift issues. The challenge arises from the sensor's body frame reference, while linear velocity requires an Eulerian frame. Various methods exist for converting reference frames, and filtering techniques may be necessary to address drift. Input on specific approaches or solutions for this common problem is sought.
hfarhadi
Hi
here is the situation; There's a spherical particle contained with a MEMS sensor (3D accelerometer and gyroscope) moving down a bed. What we want is to estimate the total kinetic energy of the particle. The total kinetic energy has two parts, translational part and rotational part. for the translational part we need the norm of the linear velocity and for the rotational part the norm of the angular velocity is needed. the sensor output delivers the angular velocity values (3D) but no linear velocity. It seems we need to conduct an acceleration integral to estimate linear velocity but the noise and drift issue is there. Also the sensor is body framed reference not inertial. For linear velocity we need to have an Eulerian frame but the sensor output is in Lagrangian frame.
Does anyone has an idea on this?
It's a standard problem. Have you done any search on the web?
Yes. there are some methods to convert frame references but I need to know how it really needs to be done and if there's any need for any filters how to solve the drift issue etc.
hfarhadi said:
Yes. there are some methods to convert frame references.
I meant that specifically tracking motion from inertial sensors is a common problem, with tons of literature on it.
Yeah, sure it is. but any idea/suggest/feedback on the case is welcome.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
