What Index of Refraction is Needed for a 104nm Coating to Cancel 550nm Light?
To design a thin transparent reflective coating for glass that cancels 550nm light, the coating must have a refractive index that allows for destructive interference. Given a coating thickness of 104nm, the required refractive index can be calculated using the formula n = λ/(2d), resulting in n = 2.64. The phase shifts at the air-coating and coating-glass interfaces must be considered, as a pi shift occurs at the air-coating interface. The refractive index of the coating can be either greater or smaller than that of the glass, which has an index of 1.52. Both scenarios must be evaluated to determine the optimal coating material for effective light cancellation.
Callix
You are designing a thin transparent reflective coating for the front surface of a sheet of glass. The index of refraction of the glass is 1.52 and when it is in use, the coated glass has air on both sides. Because the coating is expensive, you want to use a layer that has the minimum thickness possible, which you determine to be 104nm. What should the index of refraction of the coating be if it must cancel 550nm of light that hits the coated surface at normal incidence?
I know that for constructive interference, the equation is 2d=(m+\frac{1}{2})\frac{\lambda}{n}
And for destructive,
2d=m\frac{\lambda}{n}
However I'm not sure what to do with these.. or if these are exactly the equations I need to use. But these are the notes that I have for thin film.. Any help would be greatly appreciated!
Thanks in advance
Thanks in advance
The coating must cancel the 550 nm wavelength light, so it must be constructive or destructive interference?
The coating layer must be as thin as possible, so what should be m?
Well, it would be destructive since it needs to cancel light.
m should be at a minimum as well, which would be 1, right?
Yes, and you know the thickness, so what is the refractive index n?
n=\frac{550}{2(104)}=2.64
Hmm.. I was doing some other research and I found some other equations for thin-film interference..
\huge \phi=\frac{4\pi n_b t \cos(\theta_i)}{\lambda}+\phi_{r2}-\phi_{r1}
Could I make the assumption that since the speed will be greater in air than in the glass that it will experience a pi shift? Therefore, I could simplify the equation to
1=\frac{\lambda t}{4n_b}
I just found a very similar problem in my book except n for the coating was given and they were solving for the necessary thickness to cancel out 500nm of light. Could I proceed similarly?
And since the incidence is normal, cos(0)=1. Well, approximately 0, so cos(~0) = ~1
The refractive index of the coating can be either greater or smaller than the refractive index of glass. At the reflection of the air-coating interface, there is a pi shift. At the interface between the layer and the glass, the phase shift is pi if the refractive index of the coating is less then that of the glass, and no phase shift if it is greater than that of the glass. The phase shift during the path of the wave which reflects from the layer-glass interface is (4π/λ)nd.
You assumed the second case, when the net phase shift between the wave reflected from the air-layer interface and that reflected from the layer-glass interface is (4π/λ)nd-π=π, that is, 2d=λ/n.
In case the layer has refractive index is lower that that of glass, the phase shift between the reflected waves is (4π/λ)nd=π, that is, 4d=λ/n.
If you want the thickness of the antireflecting layer you must know what the refractive index of the layer is. It is usually lower than the refractive index of glass.
Ah okay, so is my approach correct? And the textbook also notes that if the speed of the first medium is greater than the speed of the second medium, there will also be a phase shift of pi.
You had two possibilities for the refractive index. I think you should give both ones.
In general, use the formula in Post #6 and take the phase shifts at the boundaries into account.
Ah okay, thank you!
