What Is the Minimum Height of a Rear-View Mirror to See the Entire Rear Window?
  • Thread starter Thread starter sweetgirl86
    Reflection
The discussion focuses on determining the minimum height of a rear-view mirror needed for a driver to see the entire rear window without moving their head. The dimensions of the rear window and the distances from the driver's eyes to the mirror and rear window are provided. Participants emphasize using geometric principles and similar triangles to derive the correct formula, highlighting the importance of understanding the relationship between angles of incidence and reflection. A successful solution was reached by applying these concepts, leading to the correct height calculation. The conversation underscores the need for a solid grasp of fundamental physics principles in solving such problems.
sweetgirl86
I have been trying to solve this problem using many equations, but am not getting the right answer. I guess I'm not using the right formula because I don't know it. Can someone please help.
The rear window in a car is approximately a rectangle, 1.17 m wide and 0.160 m high. The inside rear-view mirror is 0.600 m from the driver's eyes, and 1.23 m from the rear window. What is the minimum height of the rear-view mirror if the driver is to be able to see the entire height of the rear window in the mirror without moving her head?
do: 1.23m
di: 0.600m
ho: 0.160m
hi: ?
hi = (di/do)ho = (0.600/1.23)0.160m = 0.0780m
This is how i tried to solve it:
do: 1.23m
di: 0.600m
ho: 0.160m
hi: ?
This sounds like triangles and simple ratios, sweetgirl. Unfold the reflection, then you've got a triangle .6m long within a triangle 1.23m + .6m long. Do you know if the first answer is
.16 x .6 / 1.83 = .05245
do: 1.23m
di: 0.600m
ho: 0.160m
hi: ?
Where does this equation come from? It is wrong.
If you draw a diagram and identify the correct similar triangles, you will get the correct formula.
Physics is not about trying different formulas and hoping one of them works. It is about arriving at the correct formula by a combination of math and a knowledge of the fundamental principles.
In this case, since the rear-view mirror must be assumed to be planar, the principle that is relevant is the relationship between the angle of incidence and reflection. From there, it's just a geomtry problem.
Can you draw a diagram, label the various points and find the relationship from there? Have you come across the simpler problem where you are asked to find out how tall a mirror you need to completely view yourself? If not, it might be instructive to first attempt this simpler problem before going on to the one you have.
Thank You so much. I tried solving it the triangle way and go the right answer. And yes that's the right answer farsight. Thank you all so much. I solved the second part by myself :-).
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
