Related Rates air in a balloon
The problem involves related rates concerning a spherical balloon, specifically how the surface area changes as air is pumped into it, increasing its volume at a specified rate.
  • The original poster attempts to relate the rates of change of volume and surface area but expresses confusion about the setup of the equations. Some participants suggest finding a relationship between surface area and volume by solving for radius.
Participants are actively engaging in the problem, with some offering guidance on deriving the necessary equations. There is acknowledgment of errors in the original poster's derivation process, and a collaborative effort to clarify the application of the chain rule is evident.
The original poster indicates difficulty with related rates problems in general, suggesting a broader context of learning challenges. There is also mention of reliance on tutorials and textbooks that may not provide sufficient detail on the derivation steps.
AmiraM
Air is being pumped into a spherical balloon so that its volume increases at a rate of 70 cm3/s. How fast is the surface area of the balloon increasing when its radius is 5 cm3?
A ball with radius r has the following volume (V) and surface area (S):
V = (4/3)(πr3)
S = 4πr2
The problem seems to be asking for dS/dt at r = 5. dV/dt appears to be equivalent to S.
dS/dt = (d/dt)(4πr2)
dS/dt = 8πr(dV/dt) <--- This step is the one that's really bugging me, especially that dV/dt tagged onto the end.
dS/dt = 8π5(70)
dS/dt = 2800π
dS/dt = 8796.459
Which is apparently incorrect. I'm having a lot of trouble grasping these and other related rate problems, mainly because I am not sure how to properly set up the equations and every tutorial I've found on the subject (including my textbook) simply breeze over that step by saying "Find an equation that describes the given relationship."
Any help is much appreciated.
Well, firstly, what you'll want to do is find S as a function of V. This can be done by solving your function V = 4 pi r^3 / 3 for r, and then plugging that into the r in your function for S.
So basically, solve your volume function for r, and then plug that into the r in your surface area function.
Thanks!
Alright, so I tried what you said and came out with:
S = 4π(sqrt3(3v/4π))2
Taking the derivatives using the chain rule leaves me with:
dS/dt = 8π(3v'/4π)1/3(3v'/4π)-2/3, or
dS/dt = 8(3v'/4)-1/3
When I plug v' = 70 into the equation, it returns 2.137, which is unfortunately also incorrect. I can show my deriving process step-by-step if it helps anyone spot where I'm making my error.
AmiraM said:
Thanks!
You did something wrong here. Taking the derivative with the chain rule should yield a (-1/3) term and then v' on the outside.
You are applying the chain rule incorrectly. [tex]\frac{dy}{dx} = \frac{dy}{dt}\frac{dt}{dx}[/tex]
Yes, there was definitely something wrong with the way I derived. I tried deriving it again, step-by-step this time, and ended up with the correct answer. Thanks so much guys, you were really helpful :)
  • · Replies 33 ·
  • · Replies 30 ·
  • · Replies 20 ·
