Estimating the Size of a 1-Ton Rock: Relating Density and Volume
  • Thread starter Thread starter DSG3002
    Density Volume
To estimate the size of a 1-ton rock, the density of rock is approximately three times that of water, leading to a calculated volume of about 333.3 liters, or 1/3 of a cubic meter. The discussion clarifies that the original question is likely asking for the diameter of a sphere with that volume. To find the diameter, one must use the formula for the volume of a sphere, (4/3)*pi*r^3, and solve for the radius. This approach indicates that simply providing the volume is insufficient; the diameter must also be estimated. Understanding these calculations is essential for accurately answering the homework question.
DSG3002
How big is a ton? That is, what is the volume of something that weighs a ton? To be specific, estimate the diameter of a 1-ton rock, but first make a wild guess: will it be 1ft across, 3ft, or the size of a car? [Hint: Rock has mass per volume about 3 times that of water, which is 1kg per Liter (1000cm) or 62lbs per cubic foot.]
Well finding the volume of the ton is easy:
3 kg/L = density of rock, so volume would be 333.3 repeating Liters.
However, I'm not sure how to answer the original question "how big is a ton?" Anybody have a clear idea what's being asked? This is off a worksheet.
A liter is 1/1000 of a cubic meter, isn't it? So 333 liters is 1/3 of cubic meter. The question, I think, is asking for the edge size of a cube that has that volume.
I'm unfamiliar with what edge size is and how to find it; I'm just beginning taking Physics this semester. It talks about estimating the diameter of a 1-ton rock, but is doing so no longer necessary due to already having the volume, or am I overlooking something?
You don't think answering with the volume alone is answering the question?
No, I don't think it's quite enough. They are asking whether it is '1 ft across'. Sounds like they are actually talking about a sphere. The volume of a sphere is (4/3)*pi*r^3 where r is the radius. Set that equal to 1/3 m^3 and solve for r.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
