Estimating the Size of a 1-Ton Rock: Relating Density and Volume
  • Thread starter Thread starter DSG3002
    Density Volume
To estimate the size of a 1-ton rock, the density of rock is approximately three times that of water, leading to a calculated volume of about 333.3 liters, or 1/3 of a cubic meter. The discussion clarifies that the original question is likely asking for the diameter of a sphere with that volume. To find the diameter, one must use the formula for the volume of a sphere, (4/3)*pi*r^3, and solve for the radius. This approach indicates that simply providing the volume is insufficient; the diameter must also be estimated. Understanding these calculations is essential for accurately answering the homework question.
DSG3002
How big is a ton? That is, what is the volume of something that weighs a ton? To be specific, estimate the diameter of a 1-ton rock, but first make a wild guess: will it be 1ft across, 3ft, or the size of a car? [Hint: Rock has mass per volume about 3 times that of water, which is 1kg per Liter (1000cm) or 62lbs per cubic foot.]
Well finding the volume of the ton is easy:
3 kg/L = density of rock, so volume would be 333.3 repeating Liters.
However, I'm not sure how to answer the original question "how big is a ton?" Anybody have a clear idea what's being asked? This is off a worksheet.
A liter is 1/1000 of a cubic meter, isn't it? So 333 liters is 1/3 of cubic meter. The question, I think, is asking for the edge size of a cube that has that volume.
I'm unfamiliar with what edge size is and how to find it; I'm just beginning taking Physics this semester. It talks about estimating the diameter of a 1-ton rock, but is doing so no longer necessary due to already having the volume, or am I overlooking something?
You don't think answering with the volume alone is answering the question?
No, I don't think it's quite enough. They are asking whether it is '1 ft across'. Sounds like they are actually talking about a sphere. The volume of a sphere is (4/3)*pi*r^3 where r is the radius. Set that equal to 1/3 m^3 and solve for r.
