Relating tensions in a vertical circle help
  • Thread starter Thread starter samjohnny
    Circle Vertical
samjohnny
Question: A mass m attached to a light string is spinning in a vertical circle, keeping its total energy constant. Find the difference in the magnitude of the tension between the top most and bottom most points.
So for this one I've worked out that the tension at the top=(mVt^2/r)-mg and at the bottom=(mVb^2/r)+mg where r=radius of circle, Vb is the velocity at bottom and Vt is velocity at top. And I've also worked out that, since the total energy is conserved, Energy at top [KE+PE]=Energy at bottom [KE+PE] ==> [(mVt^2)/2]+mg2r=(mVb^2)/2.
But I don't where to go from there and work out the two tensions. Any suggestions?
Thanks
Hello.
You don't need to work out the tensions individually. You just need to find the difference in the tensions. Find an expression for the difference in tensions and then invoke your energy relation to simplify the expression for the difference.
TSny said:
Hello.
Thanks for the reply. Ok, if I'm understanding you correctly, would I equate the forces with Newton's second and obtain two vector equations for the two tensions? In which case, how would I take into account the energy?
In your first post, you gave expressions for the tension at the bottom, Tb, and the tension at the top,Tt. Use those to get an expression for the difference Tb - Tt.
Ah yes, thanks a lot I've got it now. :)
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
