Relationship Graph Between Frequency and Tension
The discussion revolves around the relationship between frequency and tension in a wire, specifically examining a graph where frequency is plotted against tension. Participants explore whether the curve representing this relationship passes through the origin and the implications of tension being zero on the wire's ability to vibrate.
  • Participants discuss the implications of a wire's natural frequency and whether the graph of frequency versus tension should pass through the origin. Questions arise about the restoring force when tension is zero and how this relates to the wire's ability to vibrate.
The discussion is active, with participants questioning assumptions about tension and vibration. Some suggest that the curve should pass through the origin, while others express uncertainty about the implications of the y-intercept and the natural frequency of the wire.
There is a note of confusion regarding the relationship between tension and the wire's ability to vibrate, with references to personal experiences with musical instruments. The concept of natural frequency is also under scrutiny, with differing opinions on its definition when tension is absent.
Stormblessed
After plotting a graph with frequency (f) of a wire on the y-axis and tension (C-Clamps) on the x-axis, a root curve was obtained. If the trend of the line is maintained, does it pass through the origin? Should it?
Note: graph attached
f is proportional to square root of T
I said that the curve would not pass through the origin if the line was hypothetically extended, as the wire can still vibrate at a specific frequency without any tension. Therefore, the y-intercept of the curve would represent the natural frequency of the wire.
I still feel like this response is wrong, however, because when I plotted a graph of f^2 vs T, the resulting line passed through the origin. But based on the f vs T graph, it doesn't look like it would pass through the origin. I also do not know for sure if the y-intercept of the curve represents the natural frequency of the wire and if the line should pass through the origin.
If the tension is zero, then where is the restoring force, when you pull on the string?
Sorry, my phone went a little haywire multiple posts.
Is the restoring force zero since
Is the restoring force zero, since tension is zero? How would that relate to the curve going through the origin or not?
if tension zero, wire cannot vibrate.
I know this experimentally because I can play guitar-like instruments and bowed instruments! :)
natural frequency of a wire is undefined.
So that means the curve does pass through the origin then?
I'm assuming that it will go through the origin, as the wire cannot vibrate without tension
Yes, you are correct. It is hard to tell if your square root curve will extrapolate and hit the origin.
  • · Replies 19 ·
17K
