Relative Motion and acceleration
The discussion revolves around the complexities of calculating relative motion and acceleration in a system with multiple rotating frames. Participants explore the application of relative acceleration formulas and the use of different unit vector frames to simplify calculations. There is confusion regarding the interpretation of angular velocities and their contributions to linear velocities and accelerations. Some users express difficulty in following the notation and deriving the correct equations, while others share their methods and results, indicating they arrive at consistent answers. The conversation highlights the challenges of applying the equations of motion in rotating systems and the need for clarity in notation and understanding of the underlying physics.
ac2707
I tried doing this, but I can't get the exact same answer as the one given
http://img246.echo.cx/my.php?image=untitled0nj.png
I use relative acceleration
a_a = a_b + \dot \omega \cross r + \omega \cross (\omega \cross r) + 2 \omega \cross V_{rel} + a_{rel}
and as
V_{rel} = 0
\dot \omega = 0
a_{rel} = 0
a_b = (\doubledot r - r\omega^2) \widehat e_r + (2\dot r+r\dot\omega) \widehat e_\theta
so a_b = b\omega^2 \widehat e_r = b\omega^2 \widehat i
and what I ended up for the answer a_a is b \omega^2 \widehat i + \omega pr \widehat j - p^2r \widehat k
fits funny, cause I got the right answer for a_b using the same formula... :confused:
oh no the 2nd order version of the BKE. I don't like that form of the equation. This is what I suggest you do... You need to define 3 sets of unit vectors here for each problem. Your first is inertial, your second is in the frame of the turn table, and your thirds are attached to the rotating discs. If you are good at taking cross products use the third as ur working frame, if you are better at taking derivatives use the frame fixed in the turntable as your working frame. Now just apply the BKE
dR/dt(inertial) = dR/dt(working frame) + w(intertial->working) X R
that is
Va = Vb + w(ab) X R
Aa = Ab + w(ab) X Va
Ab = dVb/dt in the frame of b
Vb = dR/dt in the frame of b
b is the working frame
a is the interial frame
(I tried to kinda us ur notation with the a and b stuff)
X is the cross product operator
notice if you substitue Va into my equation for Aa, and take the correct derivatives you will get
Aa = Ab + w(ab) X (w(ab) X R) + 2w(ab) X Vb + dw(ab)/dt X R
which is your equation.
well..ok...did you get the answer written on the question with that equation ?..I think that's not the problem though, as I'll be using the same formula anyway
thanks
thanks
It's been a long time since I last looked at these multiple rotating frames things, and I'm having trouble following the notation in abercrombiems02's post. In particular I'm unsure how to interpret
that is
Va = Vb + w(ab) X R
Which frame is a and which frame is b and what is w(ab) in this problem?
What if you write the velocity in the inertial frame at the moment in time of interest, and the two angular velocity vectors related to the two rotations. Is it valid to add the angular velocity vectors and add the velocity components to find a net velocity vector and find the linear acceleration as the cross product of angular velocity and velocity? I did that and got the same answers as you
\overrightarrow {v_A } = pr\widehat i - b\omega \widehat j
\overrightarrow {\omega _A } = p\widehat j + \omega \widehat k
\overrightarrow {\omega _A } \times \overrightarrow {v_A } = \left( {p\widehat j + \omega \widehat k} \right) \times \left( {pr\widehat i - b\omega \widehat j} \right) = b\omega ^2 \widehat i + rp\omega \widehat j - rp^2 \widehat k
\overrightarrow {v_B } = \left( {r - b} \right)\omega \widehat j - pr\widehat k
\overrightarrow {\omega _B } = p\widehat j + \omega \widehat k
\overrightarrow {\omega _B } \times \overrightarrow {v_B } = \left( {p\widehat j + \omega \widehat k} \right) \times \left( {\left( {r - b} \right)\omega \widehat j - pr\widehat k} \right) = \left[ {\left( {b - r} \right)\omega ^2 - rp^2 } \right]\widehat i
OMG ! : you make it look so easy ! :bugeye:
ok..how do you get this equation \overrightarrow {v_A } = pr\widehat i - b\omega \widehat j ? is it simply angular speed cross radius ? but why is it b\omega \widehat j ? is b the radius ?..looks funny, bcause b doesn't even touch the end of the circle.. :rolleyes:
and how is acceleration = \omega \times v ??
thanks
thanks
Don't ignore my caveats. I am not certain that what I have done is valid in the general case. The velocity vector is fairly simple. Point A is a distance b from the vertical axis in the figure. Since the rotation about that axis is with angular speed \omega, the linear velocity associatied with that rotation is b \omega, directed in the negative y direction. In addition, the spinning of the small wheel of radius r with angular velocity p gives a linear velocity component of rp in the positive x direction.
As for the rest of it, I don't have a good feeling about it. \overrightarrow{\omega} \times \overrightarrow{v} gives you the centripetal acceleration for circular motion at constant speed, and you can see that it is a contributing term in other equations, but it may not be the whole story. In fact it does not hold for central force motion in a plane in general, like orbital motion, when \omega is not constant. If the velocity is not tangential, the direction of the cross product will not be central. I thought maybe the constant angular velocity magnitudes in this case would make the approach valid. I guess I'm going to have to pull out the old textbooks and see what I can see. I was hoping someone else might jump in here and straigten us out.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
