Relative motion of a swimmer crossing a river
In summary: The velocity with respect to the ground will be 2.0 m/s at 49 degrees west (relative to north).In summary, the swimmer's velocity relative to the ground is 2.5 m/s [N 37 E]. To arrive directly across from her starting point, she must swim at a velocity of 2.0 m/s at 49 degrees west (relative to north). This is to compensate for the eastward flowing river at 1.5 m/s. The vertical component of her swimming motion will be 1.3 m/s, and the angle with respect to north will be 49 degrees.
chengbin
A swimmer can swim at 2.0 m/s in still water. She attempts to swim due north across a river flowing eastward at 1.5 m/s.
a) What is her velocity relative to the ground?
b) Suppose she wants to arrive directly across from her starting point. In what direction must she head? What will be her velocity with respect to the ground?
My teacher wants the solution in this format and notation.
[tex]V_{s,w} = 2.0 m/s [N][/tex]
[tex]V_{w,g} = 1.5 m/s [E][/tex]
[tex]V_{m,g} = V_{s,w} + V_{w,g}[/tex]
[tex]= \sqrt {(2.0 m/s)^2 + (1.5 m/s)^2}[/tex]
[tex]=2.5 m/s[/tex]
[tex]\tan \theta = \frac {1.5 m/s}{2.0 m/s}[/tex]
[tex]\theta = 37^{\circ}[/tex]
The relative velocity to the ground is 2.5 m/s [N 37 E]
I don't know how to setup the solution for part b. The teacher only told us only use the equation [tex]V_{a,c} = V_{a,b} + V_{b,c}[/tex]. How do I do this question? I know I have to do [tex]= \sqrt {(2.0 m/s)^2 - (1.5 m/s)^2}[/tex] to get the answer, but how would I show that in the above notation?
I don't think there is any need for for notation for part B.
In order to travel in a straight line and arrive directly across from her starting point she would have to compensate for the eastward flowing river. Which means swimming 2.5 m/s 37 degrees west (relative to north).
If you really need to show notation, you could show that:
[tex]
1.5 = \sqrt {(2.5)^2 - (2.0)^2}
[/tex]
Which is the horizontal component of swimming 2.5 m/s 37 degrees west (relative to north) - it compensates for the eastward flow of 1.5m/s.
And then with [tex]Sin\theta = O / H = 1.5 / 2.5 = 37^{\circ}[/tex]
This is the angle (relative to north) she needs to swim at.
Jared
[tex]
[/tex]
Jared
Actually you do. The answer is actually 1.3 m/s at 49 degrees. Our teacher said that's a classic problem, and most people think the answer is 37 degrees, while it is actually 49.
Therefore I need to show notation to show my understanding of how it works.
But that would only give you 1.0m/s westward, the stream would still pull you at 0.5m/s eastward. I must be missing something here.
If she swam directly into the flow she would have to maintain 1.5m/s to remain in one place. In order to travel northwards she has to turn so some of her swimming action provides the vertical motion. For every degree she turns northwards, she has to increase the speed she swims at in order to maintain the horizontal 1.5m/s component.
An aircraft with an airspeed of 60 knots, flying into a headwind of 60 knots does not have any groundspeed. It is not moving, it is stationary. I don't see how this is different.
Jared
Jared
The hypotenuse is 2 m/s, the horizontal side (water) is 1.5 m/s, and the vertical side is the velocity relative to the ground.
[tex]\sqrt {(2.0)^2 - (1.3)^2} = 1.3[/tex]
To find the angle,
[tex]\sin \theta = \frac {1.5}{2}[/tex]
[tex]\theta = 49^{\circ}[/tex]
Ah, I misread the question for my first answer (thought it wanted her northward speed the same) and took the 1.3 to be the hypotenuse because you said
In which case, 49 degrees from north is correct.
Jared
I know how to find the answer, but I need to show it, because that's half the marks.
Well you know the hypotenuse = 2.0m/s and you know the required westward speed = 1.5m/s. Plug those two into your equation and you come out with the vertical velocity. Once you have that, do as you have before and you get the angle wrt north.
The answer will be 2.0m/s at 49 degrees from north.
To get the 49 degrees, it's as you did before. Sin(theta) = O / H = 1.5 / 2.0 = 0.75
Inverse Sin 0.75 = 49 degrees wrt north.
Jared
1. What is relative motion?
Relative motion refers to the movement of an object in relation to another object. It takes into account the perspective of the observer and the movement of both objects.
2. How does relative motion apply to a swimmer crossing a river?
In the context of a swimmer crossing a river, relative motion refers to the movement of the swimmer in relation to the river's current. This can affect the swimmer's speed and direction.
3. How can the relative motion of a swimmer crossing a river be calculated?
The relative motion of a swimmer crossing a river can be calculated using vector addition. This involves breaking down the motion of the swimmer and the river's current into horizontal and vertical components, and then adding them together to determine the overall motion.
4. What factors can impact the relative motion of a swimmer crossing a river?
The relative motion of a swimmer crossing a river can be impacted by the speed and direction of the river's current, the swimmer's speed and direction, as well as any external forces such as wind or obstacles in the water.
5. How does understanding relative motion of a swimmer crossing a river benefit us?
Understanding relative motion in this context can help us make more accurate predictions about the movement of the swimmer and the time it will take to cross the river. It can also help us in making decisions about the best path to take while swimming across the river.
