Relativistic signal passing
In summary: It is also a good idea to double check your calculations to ensure accuracy.In summary, the observers in frames S and S' agree to test time dilation by using identical clocks and sending signals when their clocks read 60 minutes. They use the Lorentz transform to determine when the signal is sent and received in each frame. The observer in frame S receives the first signal after 2 hours and the confirmation signal after 4 hours. It is important to compare parameters and assumptions when working on these types of problems, as they can affect the final answer.
Scigatt
I was solving this problem, and I was comparing my answers with a classmate, and we got very different answers. I don't think I made a mistake here, but I may have missed something.
Tipler - Modern Physics 5e 1-57.
"Two observers agree to test time dilation. They use identical clocks and one observer in frame S' moves with speed v = 0.6c relative to the other observer in frame S. When their origins coincide, they start their clocks. They agree to send a signal when their clocks read 60 min and to send a confirmation signal when each receives the other's signal.
(a) When does the observer in S receive the first signal from the observer in S'
(b) When does he receive the confirmation signal?
(c)Make a table showing the times in S when the observer sent the first signal, received the first signal, and received the confirmation signal. How does this table compare to the one constructed by S?"
[tex]\beta = 0.6[/tex]
[tex]\gamma=\frac{1}{\sqrt{1 - \beta^{2}}}[/tex]
[tex]\gamma\left[\begin{array}{cc}1&-\beta\\-\beta&1\end{array}\right]\left[\begin{array}{cc}d\\ct\end{array}\right]=\left[\begin{array}{cc}d'\\ct'\end{array}\right][/tex]
a) The observer in S' sends their first signal at d' = 0,ct'. To find where this is in S we do an inverse 1D Lorentz transform.
[tex]\gamma\left[\begin{array}{cc}1&\beta\\\beta&1\end{array}\right]\left[\begin{array}{cc}0\\ct'\end{array}\right]=\left[\begin{array}{cc}\gamma\beta ct'\\\gamma ct'\end{array}\right][/tex]
This is the point in S when the observer in S' sends the signal. This signal travels at the speed of light in the -d direction until it hits the ct axis.(d = 0)
Thus:
[tex]ct_{light} = -d_{light} = \gamma\beta ct'[/tex]
The total ct is
[tex]ct\ =\ ct_{light} + ct_{hour}\ =\ \gamma\beta ct' + \gamma ct'\ =\ \gamma(1 + \beta)ct'[/tex]
entering
[tex]\gamma\ =\ \frac{1}{\sqrt{1 - 0.6^{2}}}\ =\ 1.25,\ \beta = 0.6,\ t' = 1\ hr.[/tex]
we get t = 2 hrs.
b)First, we need to find our when S' received the first message. Here we want to transform S --> S', so we use the forward Lorentz transform:
[tex]\gamma\left[\begin{array}{cc}1&-\beta\\-\beta&1\end{array}\right]\left[\begin{array}{cc}0\\ct\end{array}\right]=\left[\begin{array}{cc}-\gamma\beta ct\\\gamma ct\end{array}\right][/tex]
This is the point in S' when the observer in S sends the signal. This signal travels at the speed of light in the d' direction until it hits the ct' axis.(d' = 0)
Thus:
[tex]ct'_{light} = d'_{light} = -(-\gamma\beta ct) = \gamma\beta ct[/tex]
The total ct' is
[tex]ct'\ =\ ct'_{light} + ct'_{hour}\ =\ \gamma\beta ct + \gamma ct\ =\ \gamma(1 + \beta)ct[/tex]
This comes out to t' = 2 hr.
Now we can use the general formula in S for the confirmation pulse:
with t' = 2 hrs. we get t = 4 hrs. as the arrival time of the confirmation pulse.
c)
Time first signal sent: +1 hour.
Time first signal received: +2 hours.
Time confirmation received: +4 hours.
The table should be the same with observer S'.
Attached is a Minkowski diagram of the scenario from the perspective of S which seems to confirm my calculations.
My classmate got a bit over 4000 seconds for a) and just over 2 hours for b).
It is possible that your classmate made a mistake in their calculations. It is also possible that they are using different parameters for the problem. For example, if they use a different value for the speed of light, this could lead to a different answer. Additionally, they may have different assumptions about the time at which the clocks were synchronized (e.g., did they start at 0 seconds or 1 hour?). You should compare the parameters and assumptions that you both used to make sure that you are on the same page.
1. What is "Relativistic signal passing"?
"Relativistic signal passing" refers to the transmission of signals or information between objects or points in space that are moving at high speeds relative to each other, in accordance with the principles of Einstein's theory of relativity.
2. How does Relativistic signal passing differ from traditional signal passing?
Unlike traditional signal passing, where the speed of the signal is constant and independent of the speed of the objects or points sending and receiving the signal, in Relativistic signal passing, the speed of the signal is affected by the relative velocities of the objects or points involved.
3. What are the implications of Relativistic signal passing in practical applications?
In practical applications, Relativistic signal passing can result in time dilation and signal distortion, making it challenging to maintain accurate communication between objects or points moving at high speeds. This can have significant implications in fields such as space travel and telecommunications.
4. Is Relativistic signal passing always a concern in scientific experiments?
It depends on the scale and speed of the objects or points involved. At everyday speeds, the effects of Relativistic signal passing are negligible and can be ignored. However, at extremely high speeds, such as those in particle accelerators, Relativistic signal passing must be taken into account to ensure accurate results.
5. Can Relativistic signal passing be used to send information faster than the speed of light?
No, Relativistic signal passing does not allow for information to be transmitted faster than the speed of light. This is because the speed of light is the maximum speed at which any signal or information can travel in the universe, according to the theory of relativity.
