Relativity - facing backwards on a train
In summary, the conversation is about the concept of time and relativity, specifically Einstein's theory that time slows down for a moving object. The question is posed whether time would speed up for the observer on a moving train if a light was shone to the back of the train. It is explained that both inside and outside observers measure light moving at the same speed relative to themselves, but they define "simultaneity" differently due to time dilation and length contraction. Finally, the conversation delves into the complexities of this thought experiment and the implications it has on clock synchronization.
rczmiller
I am an amateur and I have a question about time and relativity. It is my understanding that Einstein theorized that time slows down for a moving object based on his thought experiment of an individual shining a light in the forward direction on a moving train. Since the speed of light is constant for the person on the train as it is for the person on the bank outside the moving train, time would slow down for the person on the train observing the light moving forward.
Here is my question: With everything else being equal, does this mean that if the person on the train was shining the light to the back of the train, that time would speed up for the observer on the train (so that the speed of light remained constant)?
The observer on the train doesn't notice any strange effects at all inside the train. Light travels with the normal speed in either direction.
A person viewing the inside of the train while standing still on the tracks will see time slowed inside the train, regardless of which direction the light is shining.
no. [tex]t'=\frac{t}{\sqrt{1-\frac{v^2}{c^2}}}[/tex]
the velocity term is squared, so negative velocity doesn't change dilation
To understand how both observers measure light moving at the same speed relative to themselves, you have to know not just about time dilation, but also about length contraction and about the fact that the two observers define "simultaneity" differently (for example, if an observer in a middle of a train car sends light beams out in both directions, in his the beams hit either end of the car 'at the same time', but in the frame of an observer on the track, the beam moving backwards hits the back end of the car before the beam moving forwards hits the front end). You may want to take a look at this thread where some similar issues were discussed.
Thanks for the posts!
JesseM - Thanks for the reference thread. I have read this and I am still confused. This thead uses a box with lightbulbs on either end set to flash at the same time (Noon) and the question was do these flashes reach the middle of the box at the same time. The answer that I pulled out this was that the flashes do hit the middle at the same time, but even though the observer inside the box sees the clocks as being synced, an outside observer (an observer seeing the box as in motion) will see the back clock ahead of the front clock. This would mean that the outside observer would see the back lightbulb flash prior to the lightbulb in the front. This would allow the 2 flashes to reach the middle of the box at the same time.
Even though the inside observer sees no time warping, as the box's velocity is increased, an outside observer would see time traveling slower in the front part of the box and speeding up in the back part of the box inorder to allow this experiment to continue with the same results.
Is this correct?
Is this correct?
No. The outside observer would measure all clocks used by the inside observers (whether at the front or back of the train) to be running uniformly slowly. The outside observer will also measure the clocks at the front and rear of the train to be out of synch.
No, unlike time dilation and length contraction, the clocks-being-out-of-sync effect is not something that just happens "naturally" when you increase the velocity, it's a consequence of how each inertial observer synchronizes their clocks using the procedure described by Einstein involving light-signals. If the box accelerates, then acheives a new constant velocity, and then the observer in the box resets the clocks at both ends using Einstein's procedure, then as a consequence we will see the clock in the front behind the clock in the back by an even larger amount, but both clocks will tick at the same slowed-down rate in our frame.
If the inside observer has to reset the clocks, wouldn't he conclude that he was already traveling is a certain direction prior to his acceloration?
This is where things get a bit tricky in this thought experiment.
Whether or not the observers in the train have to reset their clocks depends on how they were accelerated. If the train is accelerated in such a way that each piece of the train is simultaneously accelerated according to the outside observers, then the train observers will find that their clocks are no longer synchronized. (Realize that to the observers on the train this means that parts of the train were accelerated at different times. The train will most likely be ripped apart.)
On the other hand, if the train is accelerated in such a way that each section of train is simultaneously accelerated according to the observers on the train, then they will not have to reset their clocks. (Imagine the acceleration taking place in little bursts along the length of the train. Each set of simultaneous bursts--simultaneous according to the train observers!-- gives the train a little more speed.) But realize that according to the outside observers, this means that different parts of the train accelerated at different times, so they will measure the train clocks to be out of synch.
Thank you, thank you, thank you. All of these post have given me a lot to think about.
1. What is the concept of relativity when facing backwards on a train?
The concept of relativity when facing backwards on a train refers to the principle of relativity in physics, which states that the laws of physics should be the same for all observers regardless of their relative motion. When facing backwards on a train, the observer's frame of reference is moving in the opposite direction of the train's motion, leading to a different perception of time and space compared to an observer facing forward.
2. How does the speed of the train affect relativity when facing backwards?
The speed of the train does not affect the principle of relativity when facing backwards. According to the theory of relativity, the laws of physics remain the same for all observers, regardless of their relative motion. However, the speed of the train may affect the perceived time and space for the observer facing backwards due to the relative motion.
3. Can relativity be observed when facing backwards on a train?
Yes, relativity can be observed when facing backwards on a train. The observer's frame of reference is moving in a different direction from the train's motion, leading to a different perception of time and space. This can be observed through experiments and calculations based on the theory of relativity.
4. How does facing backwards on a train affect the perception of time and space?
Facing backwards on a train can affect the perception of time and space due to the relative motion between the observer and the train. The observer may experience time dilation, where time appears to pass slower, and length contraction, where objects appear shorter in the direction of motion. This is in accordance with the theory of relativity.
5. Is there a difference in the perception of relativity when facing backwards on a train compared to facing forward?
Yes, there can be a difference in the perception of relativity when facing backwards on a train compared to facing forward. This is because the observer's frame of reference is moving in the opposite direction of the train's motion, leading to different perceived effects of time and space. However, the principle of relativity remains the same for both observers facing forward and backwards on the train.
