What is the Relativity of Velocities Formula?
  • Thread starter Thread starter jderm
    Relativity
jderm
[STRIKE][/STRIKE]
Two spaceships approach each other, each moving with the same speed as measured by an observer on the Earth. If their relative speed is 0.89c, what is the speed of each spaceship as measured on Earth?
u=\frac{u'+v}{1+u'v/c^2}
3. My work
so ship A moves to the right at speed u, (according to an observer on earth)
and ship B moves to the left at speed v, (according to an observer on earth)
within Ship A's inertial frame, ship B is moving at u', known to be .89c
i need to solve for u, the speed on Ship A.
u=-v
substituting -v for u,
u= \frac{u&#039;-u}{1-u&#039;u/c<sup>2</sup>}
i then get
0=-\frac{u&#039;u<sup>2</sup>}{c<sup>2</sup>}+u
I am sure i am thinking of this problem the wrong way, maybe that v does not equal the negative of u?
i accidently posted this before adding my work, ill get it on in a moment
Found my error.
since the ships are approaching each other, the equation was
u=\frac{v-u&#039;}{1-\frac{u&#039;v}{c^{2}}}
then substituting -v = u
\frac{u&#039;u^{2}}{c^{2}}+u'+2u=0
which yields the correct answer of 1.8326x108 m/s
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
