Calculating Frequency of Star's Radio Signals from Earth
  • Thread starter Thread starter crosbykins
    Relativity
A star moving at 0.8c sends radio signals to Earth once every second according to its time scale. Due to time dilation, the signals are received every 2.24 seconds on Earth, resulting in a frequency of 0.45 signals per second. The calculation uses the formula Δts = Δtm/√(1 – (v^2/c^2)). A participant raises a concern about whether the increasing distance of the star affects the signal reception frequency. Overall, the discussion focuses on the implications of relativistic effects on signal timing.
crosbykins
A distant star has been measured as moving at a speed of 0.8c away from Earth. If a planet of this star sends radio signals to Earth once every second (according to their time scale), how often would we receive them (according to out time scale)?
Δts = Δtm/ √(1 – (v^2/c^2)
Δts = Δtm/ √(1 – (0.8c)^2/c^2)
= 1/ √(1 – (0.8c)^2/c^2)
= 2.24 s
f = 1/2.24 s
= .45 signal/second
Therefore, we would receive .45 signal/second
*does this look ok?
hi crosbykins! :smile:
have you taken account of the fact that the distance each signal has to travel is increasing?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
