NASA's Gravity Probe B: Testing Einstein's Theory of Relativity
  • Thread starter Thread starter Orion1
    Relativity Rocket
Orion1
NASA's Gravity Probe B satellite was launched into orbit Tuesday morning to test a key prediction of Albert Einstein's general theory of relativity.
Einstein's theory states that gravity is a distortion in the fabric of space caused by massive objects. Earth, like a bowling ball dropped on a rubber sheet, stretches the invisible fabric of space and causes smaller objects to move toward it.
That portion of the theory was confirmed by Gravity Probe A, launched in 1975.
But the theory also says that as the Earth spins on its axis, it tends to twist the fabric of space around it slightly. Gravity Probe B is designed to test that.
The heart of the satellite is a perfectly spherical quartz sphere, about the size of a pingpong ball, that is electrostatically floated in a cryogenic chamber and spun at 10,000 revolutions per minute.
The spinning sphere is a highly precise gyroscope, claimed to be the most accurate scientific instrument ever built. Researchers hope it will detect the twisting in the fabric of space, deflecting slightly in response to it. A Superconducting Quantum Interference Device, or SQUID, will detect any changes in the sphere's axis of rotation and send the results back to Earth.
The bulk of the satellite is made up of coolant to maintain both the sphere at the SQUID at a temperature near absolute zero, about minus 460 degrees Fahrenheit.
Reference:
http://www.sltrib.com/2004/apr/04212004/images/nasa.jpg
http://www.sltrib.com/2004/apr/04212004/nation_w/159275.asp
Hello orion1 is there a question here or is this simply a statement?
Terran Metric...
What is the equation for the 'Terra Metric' space-time?
s^2 = ... ?
Can a Superconducting Quantum Interference Device, or SQUID, prove such a metric?
[/color]
when do the results come in?
s^2 = ... ?
[/color]
I imagine they are using the Kerr metric for the spacetime near the turning earth. That is the solution for an axially symmetric spinning mass, and that is the one in which the frame dragging is manifested.
Metric Measurement...
Kerr Metric Boyer-Lindquist angular velocity:
\omega = \frac{2Mar}{(r^2 + a^2)^2 - a^2 \Delta \sin^2 \theta}
Reference:
http://www.gravityprobeb.com/
http://www.astro.ku.dk/~cramer/RelViz/text/geom_web/node4.html
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
