Reliability of substation configuration
  • Thread starter Thread starter bigjoe5263
    Configuration
Assessing the reliability of substation configurations, particularly between ring bus and single bus systems, reveals significant differences in operational flexibility and reliability. A single bus configuration offers low reliability, as a failure can lead to complete facility outages, making it suitable only for low-load environments. In contrast, a ring bus system enhances reliability by isolating faults to specific bus sections, allowing maintenance without load interruption. However, the ring bus is more complex and costly due to the need for additional breakers and protective relaying. Overall, the choice of configuration should align with the facility's reliability and availability requirements.
bigjoe5263
hi!.
anyone here who have an idea on how to assess the reliability of a ring bus system over an open loop/ radial system?
the ring bus is composed of three load bus connected together.
thank you
Bus configurations are an important aspect of substation reliability, operational flexibility, and cost.
Single Bus, Single Breaker configurations:
This is the simplest bus arrangement, a single bus and all connections directly to one bus.
Reliability of the single bus configuration is low: even with proper relay protection, a single bus failure on the main bus or between the main bus and circuit breakers will cause an outage of the entire facility.
With respect to maintenance of switching devices, an outage of the line they are connected to is required. Furthermore, for a bus outage the entire facility must be de-energized. This requires standby generation or switching loads to adjacent substations, if available, to minimize outages of loads supplied from this type of facility.
Cost of a single bus arrangement is relatively low, but also is the operational flexibility; for example, transfer of loads from one circuit to another would require additional switching devices outside the substation.
Line connections to a single bus arrangement are normally straight forward, since all lines are connected to the same main bus. Therefore, lines can be connected on the main bus in areas closest to the direction of the departing line, thus mitigating lines crossing outside the substation.
Due to the low reliability, significant efforts when performing maintenance, and low operational flexibility, application of the single bus configuration should be limited to facilities with low load levels and low availability requirements.
Since single bus arrangement is normally just the initial stage of a substation development, when laying out the substation a designer should consider the ultimate configuration of the substation, such as where future supply lines, transformers, and bus sections will be added. As loads increase, substation reliability and operational abilities can be improved with step additions to the facility, for example, a bus tie breaker to minimize load dropped due to bus outages.
Ring Bus configurations:
As the name implies, all breakers are arranged in a ring with circuits connected between two breakers.
From a reliability standpoint, this arrangement affords increased reliability to the circuits, since with properly operating relay protection, a fault on one bus section will only interrupt the circuit on that bus section and a fault on a circuit will not affect any other device.
Protective relaying for a ring bus will involve more complicated design and, potentially, more relays to protect a single circuit. Keep in mind that bus and switching devices in a ring bus must all have the same ampacity, since current flow will change depending on the switching device’s operating position.
From a maintenance point of view, the ring bus provides good flexibility. A breaker can be maintained without transferring or dropping load, since one of the two breakers can remain in-service and provide line protection while the other is being maintained. Similarly, operating a ring bus facility gives the operator good flexibility since one circuit or bus section can be isolated without impacting the loads on another circuit. Cost of the ring bus arrangement can be more expensive than a single bus, main bus and transfer, and the double bus–single breaker schemes since two breakers are required for each circuit, even though one is shared.
The ring bus arrangement is applicable to loads where reliability and availability of the circuit is a high priority. There are some disadvantages of this arrangement:
(a) a ‘‘stuck breaker’’ event could cause an outage of the entire substation depending on the number of breakers in the ring,
(b) Expansion of the ring bus configuration can be limited due to the number of circuits that are physically feasible in this arrangement, and
(c) Circuits into a ring bus to maintain a reliable configuration can cause extensive bus and line work. For example, to ensure service reliability, a source circuit and a load circuit should always be next to one another. Two source circuits adjacent to each other in a stuck breaker event could eliminate all sources to the station. Therefore, a low-profile ring bus can command a lot of area.
Creative thinking is enjoyable, Then think about your surrounding things and other thought products. http://electrical-riddles.com
msj.. thank you for the info..
regards
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
