Resistance between two point voltages on infinite plane
The discussion centers on the mathematical approach to calculating the resistance between two close points on an infinite plane of resistive material. Participants explore various configurations, including circular, square, and rectangular planes, and consider the implications of point contacts versus areas for resistance measurement.
  • Some participants propose that the resistance between two vertical rod electrodes depends only on the length and diameter of the rods, regardless of surrounding space limits.
  • Others argue that for a uniform resistive material, one could find the electric field distribution and integrate conductivity to derive resistance, though they note the complexity of the mathematics involved.
  • It is suggested that points have zero circumference, leading to infinite resistance, and that resistance measurements require equipotential lines or areas.
  • Some participants discuss the necessity of defining contact areas or lines for practical resistance measurements, emphasizing the importance of geometry in the calculations.
  • There is a contention regarding whether current flux remains constant across different areas, with some asserting it does while others argue it varies with geometry.
  • Several participants express skepticism about the existence of a pure mathematical solution for the problem, indicating a preference for numerical methods or finite element approaches.
  • Discussions include the need to integrate over specific variables, such as angles or lengths, to derive solutions, with varying opinions on the best approach to take.
Participants do not reach a consensus on the mathematical treatment of resistance in this context. There are competing views on the nature of resistance at point contacts versus areas, the behavior of current flux, and the feasibility of deriving a pure mathematical solution.
Limitations include assumptions about uniformity in resistivity, the definition of contact areas, and the complexity of integrating over different geometrical configurations. The discussion highlights the challenges in modeling resistance in infinite planes and the implications of varying conductivity.
Roger44
Hi
What would be the mathematical approach for calculating the resistance between two close points on an infinite plane of resistive material? And if the plane was circular/square/rectangular with the two points at the cente?
In my opinion, the resistance of one vertical rod electrode does not depend on the surrounding space limits, but only on the length and rod diameter [or radius].
The distance between rod locations has to be at least as the rod length [or height].See for instance IEEE 81/1983 or BS7430 ch.10.2 Rods or pipes.
R=ro/2/pi()/L*[ln(8*L/d)-1] where:
L is the length of the electrode, in meters (m);
d is the diameter, in meters (m);
ro is the resistivity of the soil, in ohm meters[ohm.m].
The resistance between 2 electrodes it has to be R=R1+R2 [connected in series].
If the resistive material is uniform, it is moderately simple. Find the field[/PLAIN] distribution and resulting current flow. Integrate the conductivity to get the conductance. Invert to get the resistance.
This works for more complex resistive/time distributions as well, but the math isn't obvious or easy.
Note: There are some pedantic problems. A plane has no width, thus the resistance is infinite. Charges are not current sources, they will quickly (instantly if point charges) discharge. Of course you can re-define the problem a little better and eliminate these.
The basic idea of modeling the charge density, field lines, and current flows should work for all non-relativistic problems similar to this, though there are hopefully easier methods for situations with AC signals, etc. Finding charge distributions with magnetic fields pushing the currents around is not trivial.
Points have zero circumference so they have infinite resistance.
You require two equipotential lines or areas to make a resistance measurement on a resistive sheet.
That's right, but say you have some small area, where you attach the positive ohm-meter probe, you will get equi potential curves ( the red curves ) like this:
A current will always flow perpendicular to the red curves, so within an area surrounded by two black curves ( current paths ), the current "flux" will be the same.
Now you attach the negative probe and will get this:
Again, the current flux will be the same within areas surrounded by two black curves. The resistance of such an area may be calculated:
R = σ * 0L 1/A(s) ds , where A(s) is a cross section area, s is the current path and L is the length of the path.
If the area of the plate is not infinit, the curves will of course will be distorted. I recommend a numerical calculation to solve the problem.
Anybody knows why I cannot paste two small images ?
You agree it does not work for mathematical point contacts, points must always have infinite resistance.
The minimum valid electrical contact with zero area is a line. Because that line has length the field pattern can be solved from the equipotential defined by that line. That line can be open or closed, the simplest form being a circle.
Where the contact is an area, it is only the peripheral line that defines the contact. You have chosen to use two small circular areas as electrodes. The circumference of those two circles are the equipotential line contacts with the sheet.
For the OP's infinite sheet problem, the simplest solution is to select any two circular equipotentials as electrodes. You show examples as dotted red circles in your second diagram. So long as the two circles chosen do not contact each other, have a known radius ratio and centre positions, they can be mapped onto the simple bipolar field pattern you show. The circles can be separate, or one circle can enclose the other.For the OP's bounded sheet problem the simplest solution is to define two separate parts of the sheet boundary as contact electrodes. For a square or rectangle the obvious choice is two opposing edges.Alternatively, a minimum of four separate points are required to make resistance measurements of a sheet. Firstly two points are allocated to be a current source and a current sink. The second pair of points are then used to measure the potential.
Hi
In fact the resisstance would be the same as between the metal electrodes in this image. This presentation reminds of of a similar problem I saw a few years ago where the only way was by a finite element approach. Somehow I find it hard to believe there's no pure mathematical solution to such a simple problem as mine.
Having said this, I now discover numerous replies for which I thank you, not really understanding why I was only alerted by E-Mail to the first reply, At a first glance your replies do seem to indicate that it's not so easy as that, so I'll now go through them and get back.
That is because a mathematical point cannot both deliver a current to the surface of a sheet and measure the voltage on the sheet at the same time.
Hesch, I've re-arranged you image to get a clearer idea in my head of what you're saying. Your formula R= ... is obviously true but may I saxact, but really is only the beginning.
Something went wrong, I'll continue. "obviously true but geometrically doesn't help me much. I don't know if I should integrate with respect to d theta between 0 and Pi, hopefully being able to express S and A(s) as a function of theta, or with respect to dx between 0 and infinity. I'm not , or no longer able to master this problem.
In the figure in #9, you have written a "dx" and a "dθ".
I prefer the θ because the current-flux then will be the same through all N areas. ( dI = I * dθ / 2π, seen close to the 12V-circle ).
( Hope you understand what I'm trying to express ). :smile:
Perhaps integrate over dθ using the area and length determined by θ? Of course integrate form 0 to 2π (or 0 to π and double). The area (or at least the width of the area) is a function of θ I think.
I'll give some thought to finding the functions for the length and width. They don't spring to mind. Perhaps someone else knows?
I'm not sure that's the easiest method, but hopefully it gives an analytically solvable solution.
Are we sure that the current-flux will be the same through all N areas for the same dθ seen close to the 12V-circle ?
It is not. It varies with the changing width and length, going up as the width increases and down as the length increases. That assumes an even conductivity. This should be covered by the equation -- which I still don't have.
If it helps anyone else, the field strength at any point is the linear addition of the two fields. I plan on working that into an equation for the length and width of the geometric lines. It could take some time.
I used to be smarter.
I don't agree in that. The current density will change, but the current flux will not: No current will cross a current path ( black curve ), and due to KCL the current flux will be constant within an area.
If the conductivity is not homogeneous, the equi potential curves will be distorted, and thus the current paths and the shape of the areas.
You are correct. The term "flux" can mean several things, and I meant current density. Thank you for pointing that out.
Please Hesch, what does "and due to KCL" mean?
Secondly, I still don't see why the current fluxes I1 and I2, which we can express in total ampères crossing the straight line, should be the same for a same angle at the centre..
KCL means Kirchhoffs Current Law ( the 1. law ):
The sum of currents ( calculated with signs ) flowing toward a node = 0.
In case of your attached figure, a "node" could be a boundary "I1" in the leftmost area. Now KCL states that the current flowing toward this boundary = the current flowing away from the boundary, which means that the current flux will be the same as for both shown "I1" boundaries.
If the area/diameter of the "12V" circle is very small compared to the distance between "12V" and "-" poles, the "12V"-pole cannot "sense" the "-" pole and the current density will be the same close to the "12V"-area in all directions. Thus the current flux = Idens*dθ will be the same through alle areas.
At some distance from the "12V"-pole the length of the boundaries will increase and the current density will be decreased, but the current flux = (boundary length) * (current density ) will be constant.
"If the area/diameter of the "12V" circle is very small compared to the distance between "12V" and "-" poles, the "12V"-pole cannot "sense" the "-" pole and the current density will be the same close to the "12V"-area in all directions. "
I hope you're right on this, as it considerably simplifies the problem. I thought about this quite some time, I really remain only half convinced!
You are right to be skeptical. This is definitely an approximation based on the distance to the near part of the electrode and the far part being the same distance from the other electrode and thus seeing the same voltage. But since you started with point charges, it is likely valid. It would likely not be valid for most real world problems.
My vector analysis class was many moons ago, but many of the concepts seem to apply here. The current paths will be perpendicular to the equal potential curves.
I get the feeling there should be a simple coordinate/unit transformation, but I can't think of it. For small electrodes.
Let p = qd;
p - dipole vector
q - ½ charge (the charge on one electrode)
d - displacement vector from negative to positive.
Let the origin bisect the displacement vector with the vector pointing in the z direction.
For any point r (with r as a unit vector), the electrostatic potential Φ(r) = (pr) ÷ 4πεοr2. (Does this hold for the nearfield?)
The electric field, E is the gradient of Φ. Finally, J = σE where σ is the conductivity and J the current density.
I hope this helped.
Hi
I read in a theoretical study on the Hall Effect that for a point electrode on an infinite plane, the current does emanate uniformally in all directions. So be it.
In this case, we can say that the ratio (A+dA)/dS between equipotential lines will the same for all d theta shade areas, ie (A1+dA1)/dS1 = (A2+dA2)/dS2. I'm not sure this helps much.
Could we therefore say that the ration of curve lengths AB/BO (O= origin) will be equal all round an equipotential line?
Not as far as I know. That would be true for concentric circles which these are not. It could be true, but I can't prove it.
The red equipotential lines are all circles. The black current lines must also all be circles. The circles are eccentric.
If AB/BO was constant for a particular circle then BA/AO must also be constant.
That would require A=B which is clearly not the case for eccentric circles, so the supposition must be false.
By the use of the words circle and eccentric together, are you implying that the equipotential lines are ellipses? It might help if they were, but offhand I can't see why they should follow the strict curvature imposed by a and b of ellipses.
My supposition was that, for example in this image, B1 O/B1A1 = B2 O/B2A2
See Excel image. The 6 red lines are ellipses having the same two focal points. The two black ellipses pass through these two focal points. It looks very much like the red and black lines cross at 90°. So the focal points could be the point contacts, the red ellipses equipotential lines and the two black ellipses the current paths.
An interesting graph. But of what?
They are all perfect circles. But none of them have the same centre position.
Because equipotentials are circles, they can be used to model the fields between cylindrical conductors of different diameters.
Jeff, graph of this image from the preceeding page :
Baluncore,
"they are all perfact circles" See image below. They are obviously not for a closed surface, what is the proof that they should they be so for an infinite surface ?
"they can be used to model the fields between cylindrical conductors of different diameters" Easy to say, do please carry on, assuming they are ellipses which should greatly simplify the problem.
Thread Title = "Resistance between two point voltages on infinite plane".
Years of experience. Attached are three pages from Electromagnetics. 2nd Edn. Kraus and Carver. 1973.
Start at bottom of page 81 with sect 3-19.
  • · Replies 18 ·
  • · Replies 35 ·
10K
  • · Replies 16 ·
