How do I simplify this resistor circuit for my homework?
  • Thread starter Thread starter exitwound
    Circuit Resistors
To simplify the resistor circuit, the bottom branch combines to 60 Ohms. The top right resistor is shorted out and can be disregarded. The remaining resistors consist of 30 Ohms in parallel with another 30 Ohms and the combined 60 Ohms from the bottom. The equivalent resistance is calculated using the formula for parallel resistors, resulting in 12 Ohms. This approach clarifies the circuit's simplification process for the homework assignment.
exitwound
Resistors in Series = R1 + R2 + R3... = Req
Resistors in Parallel = 1/R1 + 1/R2 + 1/R3 ... = 1/Req
Studying for a test. This sample exam went pretty well. I am having trouble with 3 out of the 20. I can't figure this one out.
The bottom branch can be combined to be Req = 30 + 30 = 60 Ohms
From there, I can't seem to find a way to combine the rest. I have the answer (B) but I can't collapse the circuit.
The top right resistor is shorted out, so it has no effect. Imagine that it's erased from the diagram.
The center point and point b are the same point.
You have 30 in parallel with 30 in parallel with (30+30).
1/[(1/30) + (1/30) + (1/{30+30})] = 12 ohms.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
