Find Telescope Diameter to Resolve Two Stars
  • Thread starter Thread starter dimensionless
    Images
dimensionless
I have two stars that are separated by an angle of 3x10^5 radians. They are both emitting monochromatic light on 600nm. I would like to find the diameter of the smallest telescope that can resolve the two stars.
For the angular limit of resolution I have
<br /> \Delta \theta = \frac{1.22 \lambda}{D}<br />
Where D is the diameter of the lens.
Rearranging I get
<br /> D = \frac{1.22 \lambda}{\Delta\theta}=\frac{1.22*600*10^{-9}}{3*10^{-5}} = 2.44 cm<br />
I'm quite sure that the answer is 2.5 cm. Where am I going wrong? Where does the 1.22 come from?
I don't think you're going wrong at all.
The resolution limit you are using is called Rayleigh's criteria. The 1.22 comes from calculating the diameter of the first dark ring of the Fraunhofer diffraction pattern due to a circular aperature (which involves finding the zeros of a Bessel function--look it up if you want more).
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
